geekinthesticks
Case That Attaches to a Tripod
Sun May 11, 2014 1:15 pm
I am looking for a case that will enclose my Pi and camera and attach to a standard tripod mount. Does such a thing exist? The nearest I can find is the Nwazet Pi Camera Box and wall mount, but this doesn't seem to have the standard tripod thread.
Paul Webster
Contact: Twitter
Re: Case That Attaches to a Tripod
Sun May 11, 2014 2:18 pm
If you can get use of a 3D printer then here is a route you could try
http://www.raspberrypi-spy.co.uk/2014/0 ... pod-mount/
ame
Sat May 17, 2014 1:13 am
Hi there,
The standard tripod thread is a 1/4"-20, so if you have any DIY skills you could perhaps add your own tripod socket. Two ideas come to mind- first, if the case material is reasonably thick (say 3mm or so) you could drill a hole and use a 1/4"-20 tap to thread the hole. The second suggestion is to buy a 1/4"-20 nut and epoxy it on to the case. If your case material is thin you could drill a clearance hole and epoxy the nut on the inside.
geekinthesticks
Sat May 17, 2014 1:26 pm
Thanks both. I don't have access to a 3D printer, so the DIY option looks best.
