king156
FOR ALL PI MODDERS
Sat May 03, 2014 11:18 am
Hi there I just got my raspberry pi the other day and installed raspbian wheezy all works well :) I was looking around and it seems some people have added fans to their raspberry pi but most are tiny 5v fans as that's all the pi can handle. SO instead I got and old AMD cpu fan and at 11.1v and made a sepertae power supply unit at 12v 5.0a and ran it from that as the pi cant handled 12v and omg this fan spins fast and works much better than the small 5v fans from ebay. I have overclocked my pi to turbo (1ghz) and with the fan my temps are at 30 degrees amx when running programs :)
ShiftPlusOne
Re: FOR ALL PI MODDERS
Sat May 03, 2014 11:24 am
I don't know, 30C is still above room temperature :roll:. Sure you don't need one of these? :D
http://hackaday.com/2013/07/20/water-co ... pberry-pi/
GTR2Fan
Sat May 03, 2014 11:54 am
king156 wrote:Hi there I just got my raspberry pi the other day and installed raspbian wheezy all works well :) I was looking around and it seems some people have added fans to their raspberry pi but most are tiny 5v fans as that's all the pi can handle.
A tiny 5V fan is all that's ever likely to be necessary. There's no harm in having fun with a bigger one though. :D
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
aTao
Sat May 03, 2014 1:05 pm
ShiftPlusOne wrote:I don't know, 30C is still above room temperature :roll:. Sure you don't need one of these? :D
Pha, rubbish! The lightweight uses aluminium to contact the ICs and transfer heat.If you're going to over do it, really over do it. Nothing less than diamond interface will do.
king156
Sat May 03, 2014 1:38 pm
yep its defo 30C how to I post a pic of it and yh I guess its just fun to mess about with it!
king156
Sat May 03, 2014 1:42 pm
hi if you check out my youtube channel there is a video of it on there would really appreciate you looking at it guys
https://www.youtube.com/watch?v=RCkxawVb2vY
My channel is called ULTIMATE RC FUN
king156
Sat May 03, 2014 1:50 pm
feedback on my fan idea please :)
GTR2Fan
Sat May 03, 2014 2:41 pm
king156 wrote:feedback on my fan idea please :)
I've nothing else to add really. It's fun but not necessary. I can understand wanting to do it just for fun though. :)
king156
Sat May 03, 2014 2:45 pm
hi yes it was just intended for fun but I may aswell keep it like that now. With recently getting my pi do you know any projects I could do with it and also for overclocking how would I get it beyond 1ghz turbo therss no more options can I manually change the values for overclcoking
ShiftPlusOne
Sat May 03, 2014 2:55 pm
king156
Sat May 03, 2014 3:12 pm
still cant get it over turbo 1ghz need help please to manually change the cpu freq from 1000mhz to maybe 1.1 or 1.15ghz
any help much appreciated :)
GTR2Fan
Sat May 03, 2014 4:30 pm
You're unlikely to get 100% stability much above 1GHz no matter how much you cool it. Try installing the Darkplaces Quake engine and leave it running for at least 15 minutes on the clocks you have now before trying to go any higher. You may find that you're already at the limit. We can look at pushing it further after.
Sat May 03, 2014 4:46 pm
The PLL's wont go any higher than 1.2Ghz anyway, so that's the upper limit anyway.
ShiftPlusOne
Sat May 03, 2014 5:02 pm
jamesh wrote:The PLL's wont go any higher than 1.2Ghz anyway, so that's the upper limit anyway.
Oh? I've seen reports of people going higher. Were they just bumping the arm_freq in config.txt without any effect? That's a little amusing, since aside from performanc eimprovements, they were reporting instability at a point higher than 1.2GHz. I guess those were just placebo and nocebo effects.
dan3008
Sat May 03, 2014 6:48 pm
or they were just pushing their pi harder, and so it crashed more often...
dan3008 wrote:Pays your money, takes your choice
