Case with built-in modular usb hub
Posted: Thu Mar 20, 2014 4:34 am
by Konek
Hello all,
This 2 cases made out of recycled Xbox CD cases with interchangeable 4 port usb hub:
https://www.dropbox.com/s/xuec6j4tqsc70q9/2Case1.jpg
https://www.dropbox.com/s/fshft32f9jyut02/2Case2.jpg
Raspberry Pi and hub can operates together with a power adapter (with hub acting actively) or both by itself (with hub being passive):
https://www.dropbox.com/s/19qdotkxlt2u6 ... mPlug2.jpg
So what you all think of it?
Re: Case with built-in modular usb hub
Posted: Thu Mar 20, 2014 7:12 am
by Raspberry5
interesting
Posted: Thu Mar 20, 2014 10:28 am
by toxibunny
The green one is pretty cool!
Posted: Mon Mar 24, 2014 10:56 am
by suicidal_orange
Not many cases have protection for the SD card and using a micro + adapter means taking the Pi out of the case to swap, your case overcomes that - good work!
I'm liking the green too
Posted: Tue Mar 25, 2014 10:57 pm
by Konek
thanks
I liked the green one too. Ran out of green material to make usb hub with.
next on wishlist: incorporate power switch if can get one
Posted: Tue Mar 25, 2014 11:13 pm
by jbeale
How did you put this together? I have not seen an Xbox CD case but I doubt it's that exact shape, did you cut out all the flat pieces and glue them together, or is the plastic folded somehow?
Posted: Wed Mar 26, 2014 2:06 am
by Konek
Yup cut out all the pieces that is needed.
Sadly have to use clear tape to hold it together for now as couldn't find plastic glue that don't leave a mess or fogged up the plastic.
All the tool you need is: exacto knife and a ruler
Posted: Wed Mar 26, 2014 2:14 am
by jbeale
I have seen plastic solvent type glue that can make clear joints but it only works on specific types of plastic (acrylic?) which may be not what you have.
http://www.curbellplastics.com/adhesive ... sives.html
They probably can be messy, but if applied correctly I've seen some very clean looking joints made that way.
Posted: Wed Mar 26, 2014 2:18 am
by Konek
I don't know what kind of plastic the case is mad of but tried 2 different solvent glues both don't gave right result.
