mark.s
My Altoids case build guide
Wed Mar 19, 2014 4:43 am
Hi There! Just as I made this it turns out somebody made a post about the Altoids tin Pi case. but there's my build guide for the one I just finished =]
I generally use my Pi to watch movies off of, because my TV doesn't support .mp4 format.
I have no experience with a rotary tool, otherwise known as a dremel. so be gentle on me!
So here's what you're going to need:
-Altoids Mint case
-Raspberry Pi
-Rotary Tool with standard attachments
-Glue gun (This I did not use)
-Sharpie or fine liner pen. I prefer the pen because I can easily rub off markings with my finger
-Safety glasses, I only had my raybans (stupid I know)
-Bundaberg Ginger Beer (optional)
Next I emptied the mints into a separate container and cleaned out the inside
I then sized up the Pi with the case, obviously some cutting had to be done for it to fit
I used my rotary tool to sand down the inside lip of the case for easier fitment
I then used some sand paper to smooth it off, only a quick sand to so I could continue
I then used my pen to mark out the areas I had to cut. I did this for all the areas that needed access
This is my first time using a rotary tool. Might explain my not so straight lines in the photos to come
here is the first cut I made for the USB and Ethernet ports. I continued to cut for all the areas that needed it.
side view of my wonky cuts
I then tried my best to smooth off the surfaces with whatever connection you call this one :?
Now is a good time to drink that Ginger beer with my best mate
obviously the Pi wasn't going to fit
I marked off the corners then cut. exposing the Pi board slightly on each corner
it fits!
I was hoping I didn't have to cut into the lid, but I needed the room
I then lined the inside with electrical tape. Didn't want "metal on metal"
Time to enjoy a movie for my efforts! with the Mints of course
Another snap of it closed
you can find my image album here →http://imgur.com/a/lIEMu/all Although the images have been scaled down.
Thanks for reading!
dan3008
Re: My Altoids case build guide
Wed Mar 19, 2014 7:50 am
nice work :)
dan3008 wrote:Pays your money, takes your choice
