Angelus88
Project: Raspberry Pi Car Navigator!
Tue Feb 25, 2014 2:29 pm
I've been working on this project for months because I don't have much time for it but it's coming out good. It's a bit uncomfortable to use but good.
Requirement:
  • Raspberry Pi
  • TFT LCD RCA/HDMI
  • 12v to 5v power supply converter
  • Bluetooth GPS Receiver
  • USB Bluetooth Adapter
Softwares used:
  • Raspbian
  • Navit compiled to support csv POI
So let's start from the beginning... First I used this:
to convert the 12v power wire that comes out behind the car radio.
Now I've found that it would be much easier and better looking using this
so I can have a simple USB plug.
Then I used this TFT LCD monitor
but I've seen that there are also touchscreens to use with the Raspberry Pi.
The bluetooth GPS receiver is one of this
connected to the Raspberry PI using a usb bluetooth adapter like this
but there are also GPS receiver inside a USB dongle like this one and it would be easier:
At last, as the GPS navigation software, I'm using Navit. You can find it here and I successfully compiled it for the Raspberry Pi with the POI support using csv files. You can find the tutorial that I wrote here.
Comments? Advices? :D
nurderfsv
Re: Project: Raspberry Pi Car Navigator!
Sun Apr 20, 2014 9:14 am
Hi! It looks really nice! 2 questions:
Does the navigation software work properly?
How do you control the raspberry pi? I did not read anything about a keyboard or similar. I'm asking because I'm planning to imply this in my car as well!
Angelus88
Tue Apr 22, 2014 7:39 am
nurderfsv wrote:Hi! It looks really nice! 2 questions:
Well, once you manage to set up Navit, it works ok! It's not the best navigation software but at least, it's the only one I found working for the RPi.
And yes, sorry, I forgot to talk about how I control it. As there's a USB bluetooth adapter, you could use it to connect a normal bluetooth mouse ;)
Or you could use a keyboard like this one.
spawnedc
Mon Dec 15, 2014 10:24 pm
You may want to check this: http://www.engineering-diy.blogspot.ro. This guy made a really good setup with quite good software. Not just navigation, but also media centre including FM radio.
CarPC
Wed Dec 17, 2014 7:29 pm
We developed the Car PC based on Raspberry Pi
May be our experiense will be useful for you
http://i-carus.com - the website of our project
pirjustice
Thu Mar 19, 2015 9:06 am
Awesome project. I am making a Heads Up Display and this helped alot. Also thanks for the Navit compile. :)
SoupSandwich
Sun Aug 16, 2015 5:46 pm
Hi was trying to use your guide to install navit but it apears that the archives are no longer avalible anything i could do?
(failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 not found)
colemckenzie
Wed Dec 23, 2015 3:01 pm
spawnedc wrote:You may want to check this: http://www.engineering-diy.blogspot.ro. This guy made a really good setup with quite good software. Not just navigation, but also media centre including FM radio.
Could this be used with non-touchscreen ? with a bluethooth mouse instead?
systemfailed
Mon Feb 15, 2016 2:36 pm
Hello out there,
I'm new to this forum. I hope this is the right place for my request.
I trying to set up the car mediacenter compiled by andrey but still without "any" sucess.
But that is just because I use the official raspberry pi 7" touch display. It is not working very well with kodi on raspbian.
I decided to try to install a carpc using osmc. So till now I've got the beseframe. Means the addons for a working car mediacenter are installed like navigation addon and the fm radio addon.
But now there is the point:
Is it possible to install Navit to osmc and start it automaticly like it is possible on raspian?
I really hope anybody can help me.
Hardware using:
- Raspberry Pi 2b
- Official RaspberryPi 7" Touchdisplay
- 32 GB SDHC Class 10
Software
- OSMC
- Navit (shoulf be installed but cannot start it)
If it is possible to get Navit working on OSMC that would be the much easier way to get an carpc software without dependency on a special type of display
Thanks for your help
josephchrzempiec
Tue Jun 21, 2016 7:58 am
Hello i was wondering what type of GPS module is that?
SonOfAMotherlessGoat
Tue Jun 21, 2016 6:56 pm
A quick Google Images search turned up this:
http://www.canadagps.com/Gtop_G33.html
Account Inactive
Kailash Thakurpersad
Wed Aug 24, 2016 11:32 pm
Hi, I'm an mechanical engineering student and want to build this exact system to put onto a pedal bus. Could you be kind enough to email me the full tutorial (hardware wiring) and programming for this system? I've never worked on this system before so all help will be appreciated. And lastly would this be applicable in South Africa?
