Quote from gbulmer on November 21, 2011, 13:54
Quote from abishur on November 21, 2011, 13:36
Interesting... so if we use the GPIO pins to supply 5V, then we need to make sure to include our own voltage protection (since it's coming in after all the voltage protection)? Or am I have a mass fit of dyslexia?
The microcontroller GPIO pins can't supply 5V directly, they can only supply 3.3V. (don't quite do 3.3V, as there is usually a little voltage drop inside the chip)
I don't believe any of the GPIO's are 5V tolerant (can't see anything on the wiki), so the only way to 'supply' 5V will be via an external device, e.g. bipolar-transistor, MOSFET, or IC.
Check the post from gert I'm referencing or the post from wizard above, two of the GPIO pins are attached to the 5V rail (though as Wizard says, I don't think they are also attached to the SoC, so it's a semantics issue)
Yes, semantics is the only stuff that matters
Okay, so this is about connections on an R-Pi I/O connector, and not GPIO pins. It might be helpful to avoid using the term 'GPIO pins' unless it is referring to pins connected to GPIO pins on the SoC.
Maybe the discussion about power connections might be conflating several different use cases, or types of user?
I have several different target audiences, including the electronics neophyte, and me.
I am happy having a simple 'polyfuse' between the R-Pi power supply and the 5V pin (and 3.3V pin) on an R-Pi I/O connector. I occasionally make mistakes, and both school children and adults often make mistakes when using breadboard, so a polyfuse somewhere in the power rail, before it is exposed to the 'breadboard user", is sensible.
If it isn't on the R-Pi, I'd likely put one on an I/O adapter board intended for the "breadboard users".
