MoonShadow
Re: Piratebox
Fri Sep 09, 2011 7:45 pm
I want to make a piratebox (http://wiki.daviddarts.com/PirateBox) and the Raspberry Pi looks ideal. Does anyone know if the built in wifi adapter is capable of infrastructure mode? I'd love to be able to put a Dash7 digital radio on one as well.
DanielSilva
Re: Piratebox
Fri Sep 09, 2011 7:58 pm
The Raspi does not have built-in wifi.
MoonShadow
Re: Piratebox
Fri Sep 09, 2011 8:01 pm
I'm sorry, I thought it did. Is there an expansion card for wifi? Even if there is not, just using the RaspPi as the piratebox server connected via a crossover ethernet cable to an off the shelf wifi router should work fine.
Re: Piratebox
Fri Sep 09, 2011 9:40 pm
Various USB WiFi dongles work. I'm using one right now.
Don't think you need crossover if you are connecting to a router.
obarthelemy
Re: Piratebox
Fri Sep 09, 2011 10:15 pm
I think the idea is to avoid a separate router. We need to find hardware and software to setup the Pi as a Wifi router, on top of everything else ^^
Warringer
Re: Piratebox
Sat Sep 10, 2011 9:05 pm
A couple of WiFi dongles can be used as access point. Under Linux that is relatively easy.
mediamind
Re: Piratebox
Wed Dec 28, 2011 8:44 pm
These wireless adapters should work:
TP-Link TL-WN821N V3
TP-Link TL-WN822N V2
Both chipsets use the ath9k-htc driver and support 802.11n speeds w/ hostapd
Check out this tutorial on Jeff Doozan's forum for setting up an Access Point with a Dockstar running Debian: http://forum.doozan.com/read.php?2,6300
Also, vMatthias Strubel's PirateBox page outlines how to setup PirateBox networking http://piratebox.aod-rpg.de/do.....i/doku.php
advancedbasic101
Re: Piratebox
Wed Dec 28, 2011 11:27 pm
Whoa I had a similar idea a while ago but on the other end of the spectrum--creating a small, portable AC/DC powered box that multiple parties can securely communicate with in order to chat and/or share files.  Either way, the RPi paired with a USB wireless card acting as a "router" would be pretty useful (and easy to fit into a very small case including a power source).
minitweak
Re: Piratebox
Thu Jul 26, 2012 6:10 am
RasPi model "A" should have built in wifi
Re: Piratebox
Thu Jul 26, 2012 8:36 am
It won't I'm afraid.
cave
Re: Piratebox
Sat Nov 10, 2012 10:51 pm
There are some HowTo's to create a PirateBox Router with OpenWrt
There are woriking images for OpenWrt available.
There are working PirateBoxes on Debian with plug computers.
Looks like it is now the time to create a Raspberry-PirateBox
I would suggest to use the Pi with OpenWrt if you want Router capabilities only. OpenWrt is also capable of other things like routing.
opkg update && opkg install anything ;)
http://cavebeat.blogspot.co.at
dan3008
Re: Piratebox
Sun Nov 11, 2012 1:15 am
Maybe a silly idea, but if piratebox isnt working, why not just mount an external hard disk, or any other memory, as a samba drive, along with using Hostapd (and wifi dongle). From there, a client interface shouldnt be hard to make.
dan3008 wrote:Pays your money, takes your choice
