chris_c
Re: Punnet - a print at home cardboard case
Sat Jul 28, 2012 10:45 am
raspfly wrote: (1) If we have a paper / plastic sheet cut out to make a case for RP can static electricity create some problem for RP ?
Paper is unlikely to cause a static problem, and plastic may well if you run it up and down the carpet regularly, plenty of people have used paper/thin card without issues and I haven't heard of anyone complaining their plastic case destroyed their Pi, while static is very much a problem for isolated components, a complete board like for example the pi will tend to be much more resilient to static problems, although you could no doubt prove me wrong if you tried hard enough....
(2) How do we fix RP inside the case ? Or is the case small enough to stop RP from moving inside the paper case ?
between the connectors (especially the usb for example) and the shape of the board it fits without any slop
SergeantFTC
Sat Jul 28, 2012 1:58 pm
E wrote:
FX4 wrote:This is great, any chance at an 8x11 version. It's a bit hard to come up with A4 stock here in the U.S..
I'd suggest downloading the .SVG version and changing the page size in Inkscape. It should fit ok if you delete the instructions or print them on another sheet.
I went ahead and did this. I haven't tested it yet (will report back later as to whether it fits or not) but it should work. I am attaching a zip file which contains both a PDF and an SVG.
Punnet(US_Letter).zip
(32.26 KiB) Downloaded 1494 times
raspfly
Sat Jul 28, 2012 6:43 pm
Thats good. I would also like to ask,
the cardboard box in which Element 14 has sent me RP is strong enough and its outside height is abt 23 mm. Looks nice, cute and small. Why is it that our Punnet RP case has much more height ? Is it for ventilation ? In that case does RP hangs a few mm above the inner surface of the case ?
Cardboard box
E
Sat Jul 28, 2012 7:18 pm
raspfly wrote: I would also like to ask, the cardboard box in which Element 14 has sent me RP is strong enough and its outside height is abt 23 mm. Looks nice, cute and small. Why is it that our Punnet RP case has much more height ? Is it for ventilation ? In that case does RP hangs a few mm above the inner surface of the case ?
It's a bit taller than the Raspberry Pi itself to help strengthen it a little against any accidental impact on the top, and to allow a good size of tuck in flap on the lid.
raspfly
Sat Jul 28, 2012 7:41 pm
Ok, i understand the reason.
Well, if u do not mind, can u kindly direct me to the link for the 'final' A4 version of Punnet Case. There have been a lot of modifications spread over 6 pages. So a lil confusing as to which one is the final one. I would like to try both svg and pdf versions.
SergeantFTC
Sat Jul 28, 2012 7:50 pm
raspfly wrote:Ok, i understand the reason.
If you scroll down here: http://www.raspberrypi.org/archives/1310 there are links to both PDF and SVG versions of the final design (mark 1).
SergeantFTC
Sat Jul 28, 2012 7:55 pm
The version of the Punnet that I modified for US Letter paper works like a charm. :D
raspfly
Sat Jul 28, 2012 9:27 pm
SergeantFTC wrote:The version of the Punnet that I modified for US Letter paper works like a charm. :D
Thats good, but i am not in US so i need one for A4. I hope the link that u mentioned above is the one i need. Thanx !
FX4
Sun Jul 29, 2012 1:35 pm
Thanks for doing this. My son is in need of case and this will be perfect for him.
mac499
Re: Punnet - a print at home see-thru case
Sun Jul 29, 2012 9:59 pm
I borrowed my beloveds crafting stencil cutter thingy. ( A Silhouette Cameo It's basically a printer X-Y plotter with a knife rather than a pen). Then I edited the SVG using Inkscape to remove the text and fold lines. Dropped it to .png, Imported it to the X-Y software after a bit more manipulation and it's ready to go.
A quick paper test piece then feed the silhoette a sheet of thick plastic The stuff you use in comb binders as document covers; et voila, one transparent Punnet, almost as good as die cut.
I also use one of those USB chargers with interchangeable tips, so I leave the Tip in the Pi and unplug the lead to avoid strain on the board..
Cheers MAC
jrt_ms1995
Mon Jul 30, 2012 2:55 pm
Thank you, Sergeant, I think I'll try this while I continue to continue to wait for my NCSU red & white case from ModMyPi.
John
bursar
Mon Jul 30, 2012 3:32 pm
Just want to say thanks for making this available :) I've just printed one out on standard A4 paper and it works pretty well. Next job is to find some card stock and make one that's a little bit more sturdy.
http://mmm-pi.co.uk - my adventures with a Pi
AndrewJohnson
Mon Jul 30, 2012 7:32 pm
I have converted the PDF into a 600x600 dpi Jpeg
http://homepage.ntlworld.com/ad.johnson ... design.jpg
and then I added a little design - hope this doesn't upset anyone!
http://homepage.ntlworld.com/ad.johnson ... 600dpi.jpg
Approx 1.5 megs each file
Dreeass
Mon Apr 08, 2013 6:43 pm
I've edited some stuff about the SVG and made it a little bit more easy to print with colour, I have made a topic about it here.
Increase attachment and avatar size limit or use a third party system?
jakespikey
Sat Jul 06, 2013 3:55 am
Hi guys, was just reading through the thread as I was interested in putting this case together however I have a Raspberry Pi Model A not B, is there a version made for this one as well?
Pill
Wed Feb 19, 2014 5:19 pm
My design for the Punnet:
http://cl.ly/3A2n382l0S2T
taichi
Wed Apr 16, 2014 5:36 am
Thank you very much for your Fantastic job!
I was looking for drawing of paper case, then hit punnet.
When I assembled your case, I found a margin touching RCA Video Connector.
I add just a little bit changes:
I changed position of hinge, because of glue margin touching RCA Video connector.
I added small cut on margin, because of holding top cover and easy to open.
I changed shape of top hole, and broken line.
I changed some label text.
I will soon teach programing for kids with RaspberryPi, and I also want kids to make Pi Case by their hand.
And I also want to cut the case by cutting Plotter(Silhouette Studio) for kaizen prototyping, so I traced and convert your PDF to Silhouette Studio file with above changes.
Here is link to PDF and Silhouette Studio files
https://app.box.com/s/ff0t3wqwajfa1ytv7w2b
The attachment raspicase-small.jpg is no longer available
bentignor
Tue Jul 01, 2014 3:20 am
I just finished my Punnet case... Took longer than it should have to get ahold of card stock, configure my printer to accept it, and then carve it out without the right tools. I'm nonetheless happy with it.
/Users/bentignor/Desktop/photo 1.JPG
/Users/bentignor/Desktop/photo 2.JPG
/Users/bentignor/Desktop/photo 3.JPG
/Users/bentignor/Desktop/photo 4.JPG
Tue Jul 01, 2014 8:24 am
bentignor wrote:I just finished my Punnet case... Took longer than it should have to get ahold of card stock, configure my printer to accept it, and then carve it out without the right tools. I'm nonetheless happy with it.
You've provided links to your own machines images - you will need to upload them somewhere first if you want people to take a look.
H_M
Wed Jul 23, 2014 7:34 am
Add a cutout for to access gpios from jumper wires and also add a label, like this guy did http://www.sh-hackspace.org.uk/2013/08/ ... clude.html.
Hoping to get update from you soon. ;)
polymap
Fri Aug 08, 2014 2:01 pm
I found a very well crafted cardboard Punnet for the Raspberry PI Model B and the new Model B+ too at Etsy.
https://www.etsy.com/de/listing/1736632 ... r-b-karton
Model B+
Model B
imaduddin93
Sun Mar 22, 2015 11:38 am
Great idea! You just made my day! Are you planning on designing one for Pi 2?
Sun Mar 22, 2015 2:40 pm
imaduddin93 wrote:Great idea! You just made my day! Are you planning on designing one for Pi 2?
The B+ version will fit a 2B as the connectors are identical.
RooPi
Sat May 09, 2015 3:46 pm
Hello
I'm a big fan of the original Punnet case, so I adapted it to fit the Raspberry Pi 2 (and maybe B+? I don't have one to try it on).
The holes are roughly in the right place, and it's usable as is, but it would benefit from some tweaking if you have time. Also, the PDF is layered, so you can easily turn the port labels and instructions off for printing, if you wish.
Download links:
PDF: https://www.dropbox.com/s/i4r50izv67mpn ... _v1_00.pdf
SVG: https://www.dropbox.com/s/ov46st1poywtv ... _v1_00.svg
Hope this is useful to someone!
Eton Mess
Thu Jul 30, 2015 12:47 pm
Here's a version that fits the Raspberry Pi 2 (or B+), directly modified from the original punnet case. This one is styled more like the original punnet than most of the other Raspberry Pi 2 cases that I've found, and I tried very carefully to get the cut-outs for the ports (and even the status LEDs) to line up pretty precisely. I've included some pictures of the results below. You can download it here:
https://www.dropbox.com/s/rad6vpd5drr6c ... Pi%202.zip
The zip file contains both SVG and PDF files, in both A4 and US Letter size paper.
