mnorthfield
The project that never came out... The Slurpr!
Thu May 17, 2012 3:49 pm
This would be a neat little project for the RPi, if someone is interesting.
http://bomega.com/2007/05/29/the-slurpr ... ss-points/
Just plug in two WIFI-cards to the USB ports and your computer to the ethernetport.
Would this be possible? I mean, the RPi is a BIT more powerful then The Slurpr! And maybe add more WIFI-cards if you connect an USB-hub to the RPi?
-- Max
abishur
Re: The project that never came out... The Slurpr!
Thu May 17, 2012 4:01 pm
Interesting idea. It's ultimately going to be relying on a single USB bus so you're going to face a bottleneck on traffic speed.
Dear forum: Play nice ;-)
mnorthfield
Thu May 17, 2012 4:27 pm
I know that this depends on the speed that the USB-ports of the RPi is capable. Just a wild guess, what speed do you think will be possible? I haven't received my RPi yet to I can't try this out.
pyrater
Mon Feb 15, 2016 8:06 pm
Yes i am building this on Kali Linux 2.1 with a Raspi 2 B+ (4 usb ports). Ill let you know how it comes out.
so far i have..
1 x PiTFT Plus Assembled 320x240 2.8" TFT + Resistive Touchscreen
1 x Pi Model B+ / Pi 2 Case Base - Clear
1 x Faceplate and Buttons Pack for 2.8" PiTFTs
1 x Raspberry Pi 2 B+ v1.1
4 x USB wifi Adapter cards
Using Kali Linux 2.1 & Custom Wan Scripts
ref: http://9m2pju.blogspot.com/2014/06/load ... xthop.html
mikerr
Fri Feb 19, 2016 2:26 pm
OP's link is dead, but web archive has it:
http://web.archive.org/web/201312021032 ... ss-points/
pyrater
Mon Feb 22, 2016 1:25 am
happy to report that i got it to work! wasnt able to use Kali had to switch to openwrt. I will post pics and stuff once i get all the correct parts in so its not such a hack job.
pyrater
Tue Mar 15, 2016 1:26 am
Its coming along. Ended up using a RPI 2 B and a RPI ZERO since the openwrt/adafruit community was 0 help.
I am using the RPI Zero to drive the piTFT on raspbian which connects to the RPI 2 B (running OPENWRT with mWAN) via wifi (will use UART once complete) to pull the variables that are displayed on the piTFT.
I plan on adding leds to the front of the case to display mwan status up or down, not sure what the bottom leds will be used for yet.... More work and more to follow:
I still need to finalize the internals (UART connection and LEDs)
Sand and repaint the outside
Add " piSplurpr! " stickers to the outside in white + various other labels
Find a clean easy way to power both usb ports at once.
FULL PICTURE LIBRARY AT:
http://imgur.com/a/a9bB7/all
toxibunny
Wed Mar 16, 2016 3:19 am
nice!
note: I may or may not know what I'm talking about...
pyrater
Sat Mar 19, 2016 2:37 am
Got it working!! W00T! now just a bit more scripting but its 80% complete.
More pictures: http://imgur.com/a/R3Quz
Video of LEDS working: https://vid.me/jAht
