riskpw
what is how connect my tft lcd on the Raspberrypi ?
Fri Sep 13, 2013 5:37 am
i have a tft lcd :
i buy in the ebay : http://www.ebay.com/itm/271171541744?ss ... 1497.l2649
but, i am not using this tft lcd.
i following refer on the post : HY28A
http://www.raspberrypi.org/phpBB3/viewt ... 64&t=48967
https://github.com/notro/fbtft/wiki/LCD-Modules
http://www.geeetech.com/wiki/index.php/ ... difinition
but, it do not display(tft lcd).
what are how to connect raspberrypi gpio pin and tft lcd pin ?
i need that yours help .
texy
Re: what is how connect my tft lcd on the Raspberrypi ?
Fri Sep 13, 2013 12:23 pm
it's not easy to connect that type of display to the Pi without additional hardware due to the parallel 16-bit data bus.
You will need some form of latching the data bus in to 8-bit packets.
The HY28A-LCDB (as you mentioned), is much easier to connect to due to the SPI serial bus it uses for both display and touch panel.
See this example :
http://www.raspberrypi.org/phpBB3/viewt ... 93&t=53144
Texy
riskpw
Mon Sep 16, 2013 3:58 am
texy wrote:Hi,
See this example :
Texy
I see your post that "2.8" TFT + Touch Shield Board".
if i made my lcd, this post write it.
Thanx Texy.
riskpw
Mon Sep 23, 2013 12:07 am
texy wrote:Hi,
See this example :
Texy
hi Texy
i solved my problem.
my mistake,My TFT LCD differ HY-28A.
My LCD Spec. is like to ITDB02-2.8.
So,it is change connect the R-Pi and TFT LCD.
great !!! i operate my tft lcd on the raspberrypi.
my lcd test movie
o sample code : http://www.youtube.com/watch?feature=pl ... vp4EmNGaGE
o raspberrypi console : http://www.youtube.com/watch?feature=pl ... hCizUQYGWU
and i compile touch module(XPT2046) drive on the raspberrypi.
thanx Texy.
i reference post that website.
o http://blog.iteadstudio.com/tag/itdb02/
o http://famory-toure.blogspot.kr/2013/07 ... ry-pi.html
o https://github.com/notro/fbtft/wiki/LCD ... #itdb02-28
o https://github.com/notro/fbtft/wiki/How-it-works
o https://github.com/notro/fbtft/wiki/FBT ... ld-process
o http://www.whence.com/rpi/
semofa
Wed Jun 10, 2015 9:16 pm
HI, I know It have been a while from last post. I'm sorry
can you explain more how you did that. I have a 3.2 inch lcd that has a XPT2046 driver
Wed Jun 10, 2015 9:33 pm
semofa wrote:HI, I know It have been a while from last post. I'm sorry
Yes over the last 18 months drivers and kernel have both been updated, therefore this post is not totally relevent, try this recent post as very recent:
viewtopic.php?f=45&t=108432&p=745958
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
