Tue May 01, 2012 10:40 am
I have one of those 480x234 (or whatever) displays in the form of a miniature TV. Attaching the composite input to my BBC Micro, I found that text was legible (even showing the top line - normally hidden on a CRT without adjusting the scanout) but graphics would be distorted, because it doesn"t have a true rescaler to fit 576 interlaced lines of input onto the ~240 physical lines of the display - instead it simply deletes scanlines more or less at random.
For serious use with an R-Pi, I think I would definitely hold out for an 800x480 or, even better, a HD display with digital input - which are apparently available in this size, if you look hard enough. The HD displays would have an extremely high pixel density, similar to Apple"s latest gadgets, but it"s worth making sure the physical display panel really has the claimed resolution, since downscaling would be a shame.
Cheers on that bit of advice
It would be nice to find an HD display, at 7". But I want to keep the whole product including the Pi itself below $150. Or at least around that number, mainly because the cheapest android tablet I"ve ever seen was that price, and it was terrible in comparison to this. But also because you are making it yourself, so unless your good with your hands, it"s not going to look like the best thing ever.
