dpslwk
Re: Slice of pi - GPIO breakout board
Thu Apr 26, 2012 12:03 pm
A lot of people (like myself) are still waiting to get there hands on an actual R-Pi, and there are people also waiting for the Gertboard.
For anyone lucky enough to all ready have a pi (or that just cant wait) and interested in playing with the GPIO's, I'd like to introduce the "Slice of Pi" from Ciseco plc.
This is a simple GPIO breakout board with prototyping area and an XBee style connector.
The Xbee style connector is great as it quickly allow people to get stuck in adding wireless sensors & projects straight onto the Pi via the Serial UART.
Most Xbee shaped devices like the XRF / XBee / RN-XV / XBT / RF-BEE etc run at 3.3v and so don't need any logic level conversion to use with the R-Pi
And of course XRF/XBee's have been used to talk to Arduino and other micros already so there is plenty of example code out there.
As soon as I get my R-Pi I'll be working on some examples using XRF's with various sensors and will try to post back here.
The Slice of Pi is already available to buy from the Ciseco web-store http://shop.ciseco.co.uk/slice-of-pi/
Matt
wirelessthings.net
OpenMicros.org
MattPurland
Thu Apr 26, 2012 12:13 pm
http://shop.ciseco.co.uk/slice-of-pi/ says:
At a special price of £3.14
Yet it's £3.25 ex VAT
Regardless, that's a nice bit of kit - could definitely come in handy!
ciseco
Thu Apr 26, 2012 12:41 pm
Whoops, Spencer saw that in the description and has changed the advert. The price reflects we had to go to another PCB house as the first couldn't organise an itch in a flea pit.
Miles
HansH
Thu Apr 26, 2012 6:20 pm
it would be nice if it would not exceed the width of the RPi pcb.
But it seems its wider... , am I correct ?
dpslwk
Sat Apr 28, 2012 9:28 am
The Slice of pi is 52.5mm x 36.5mm and so should stay just with in the size of the R-Pi.
Looks like my R-Pi is not going to be here for another 4 weeks so can't check for myself till then
Matt
wirelessthings.net
OpenMicros.org
HansH
Sat Apr 28, 2012 3:42 pm
Ok, that is ok, if will fit...
I like that board, because it will move the most important headers to the top of the Rpi
So I can do :
I assume the top connecters 1x8 are 8.5mm high ?
and the xbee connectors (1x10)  are 4.3 mm high ?
The RPi GPIO connector is not very well placed, I rather had that it would not be that far in the corner but a 2 - 3 mm towards the RCA connector.
I think I am going to redesign the back and add some extra space, so there is more room for this breakout board in the back.
Yeah I know, I also am waiting for a RPi... got end June now.. but I hope it will be sooner.
Can I already order a breakout board ?
dpslwk
Sat Apr 28, 2012 4:00 pm
yes they are standard connector heights
nice case design
and yes they are all ready avalible to buy direct from
wirelessthings.net
OpenMicros.org
HansH
Sat Apr 28, 2012 4:08 pm
thx, I ordered 2 of them....
HansH
Sun Apr 29, 2012 3:34 pm
Redesigned my case, made it longer so there is enough space behind the board, also the xbee connectors is now reachable
Power connector was a problem.. took some time...
But you can see the advantage of this breakout board, you get the gpio connectors on top of the case.... So fantastic for connecting a LDR or so
dpslwk
Sun Apr 29, 2012 3:38 pm
We now have some pic's of the slice of pi on an a R-Pi
http://openmicros.org/index.ph.....spberry-pi
wirelessthings.net
OpenMicros.org
dpslwk
Mon May 07, 2012 9:20 am
As prommised i"ve started doing some examples with the the Raspberry Pi and the Slice of Pi.
I"ve started with the old favourites LED"s and buttons
Here"s the Slice I used
And the post is on my blog
Getting Started with Raspberry Pi GPIO and Python
Matt
wirelessthings.net
OpenMicros.org
