Gary Littlemore
Carputers
Tue Jul 30, 2013 12:00 pm
For all those who are looking to create a Carputer, This kickstarter is a must. I've backed... http://kck.st/17PuWpb
3b+, 2b, b+, b, Zero & Zero-W
tekmanro
Re: Carputers
Thu Aug 01, 2013 7:24 am
Is there an open source alternative I could try building on my own?
Just can't bring myself to spend $28 on the power supply when the entire computer cost $25 :roll:
Jerry_k
Re: Carputers
Tue Aug 06, 2013 11:56 am
it looks like step-down dc-dc controller:
http://www.ebay.com/itm/12V-to-5V-2A-DC ... 27ce66b2d1
with transistor (probably NPN) and some chip (dont know for what is usefull)..
Principe: When ignition switch is on, Gpio = HIGH, When ignit. is turned off, GPIO = low, rpi is shutting down (you can do with python code), while rpi is turning off, capacitor is discharging, and after discharge, rpi is disconnected.. maybe one diode between ignit. and capacitor could be good because capacitor could discharge wrong way, and much faster...
free alternative looks like:
Pi Power Supply.jpg (24.55 KiB) Viewed 1818 times
tekmanro
Re: Carputers
Wed Aug 07, 2013 11:00 pm
Jerry_k wrote:it looks like step-down dc-dc controller...
I don't think it's that simple. For starters, a capacitor wouldn't be enough to supply sufficient power for the Pi to shutdown (unless it's a boatload of Farads), since the Pi can take several seconds to safely shutdown.
It probably has a microcontroller and a relay, with perhaps an optocoupler off the Ign/Acc line into a micro GPIO. My guess is it also (or should) have 2 power regulators (a very small switching one for the micro and a larger one to power the Pi+accessories). Otherwise if there was a single large regulator you would wake up to a dead car battery after a long weekend.
mraught
Re: Carputers
Tue Aug 13, 2013 1:06 am
I also backed this kickstarter. I have one of his original style (with rocker) switches and it works perfectly. I joked that it was almost a disappointment because it was so easy to set up, I didn't have to fight it to get it working. :) I love it though. I backed the kickstarter for the car version and I also ordered 2 of the newer style (one with switch, one without) as well.
-mark
