sudo apt-get install ncursesCode: Select all
-- Company:
-- Engineer:
-- Create Date: 09:07:40 07/03/2013
-- Design Name:
-- Module Name: invert_top - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity invert_top is
Port ( PB : in STD_LOGIC;
LED : out STD_LOGIC);
end invert_top;
architecture Behavioral of invert_top is
begin
LED <= not PB;
end Behavioral;
#PACE: Start of Constraints generated by PACE
#PACE: Start of PACE I/O Pin Assignments
NET "LED" LOC = "P2" ;
NET "PB" LOC = "P1" ;
#PACE: Start of PACE Area Constraints
#PACE: Start of PACE Prohibit Constraints
#PACE: End of Constraints generated by PACE
cpldfit: version P.40xd Xilinx Inc.
Fitter Report
Design Name: invert_top Date: 7-11-2013, 3:29PM
Device Used: XC9572-7-PC44
Fitting Status: Successful
************************* Mapped Resource Summary **************************
Macrocells Product Terms Function Block Registers Pins
Used/Tot Used/Tot Inps Used/Tot Used/Tot Used/Tot
1 /72 ( 1%) 1 /360 ( 1%) 1 /144 ( 1%) 0 /72 ( 0%) 2 /34 ( 6%)
** Function Block Resources **
Function Mcells FB Inps Signals Pterms IO
Block Used/Tot Used/Tot Used Used/Tot Used/Tot
FB1 1/18 1/36 1 1/90 1/ 9
FB2 0/18 0/36 0 0/90 0/ 9
FB3 0/18 0/36 0 0/90 0/ 8
FB4 0/18 0/36 0 0/90 0/ 8
1/72 1/144 1/360 1/34
* - Resource is exhausted
** Global Control Resources **
Global clock net(s) unused.
Global output enable net(s) unused.
Global set/reset net(s) unused.
** Pin Resources **
Signal Type Required Mapped | Pin Type Used Total
Input : 1 1 | I/O : 2 28
Output : 1 1 | GCK/IO : 0 3
Bidirectional : 0 0 | GTS/IO : 0 2
GCK : 0 0 | GSR/IO : 0 1
GTS : 0 0 |
GSR : 0 0 |
Total 2 2
** Power Data **
There are 1 macrocells in high performance mode (MCHP).
There are 0 macrocells in low power mode (MCLP).
End of Mapped Resource Summary
************************** Errors and Warnings ***************************
WARNING:Cpld - Unable to retrieve the path to the iSE Project Repository. Will
use the default filename of 'invert_top.ise'.
************************* Summary of Mapped Logic ************************
** 1 Outputs **
Signal Total Total Loc Pin Pin Pin Pwr Slew Reg Init
Name Pts Inps No. Type Use Mode Rate State
LED 1 1 FB1_5 2 I/O O STD FAST
** 1 Inputs **
Signal Loc Pin Pin Pin
Name No. Type Use
PB FB1_2 1 I/O I
Legend:
Pin No. - ~ - User Assigned
************************** Function Block Details ************************
Legend:
Total Pt - Total product terms used by the macrocell signal
Imp Pt - Product terms imported from other macrocells
Exp Pt - Product terms exported to other macrocells
in direction shown
Unused Pt - Unused local product terms remaining in macrocell
Loc - Location where logic was mapped in device
Pin Type/Use - I - Input GCK - Global Clock
O - Output GTS - Global Output Enable
(b) - Buried macrocell GSR - Global Set/Reset
X(@) - Signal used as input (wire-AND input) to the macrocell logic.
The number of Signals Used may exceed the number of FB Inputs
Used due to wire-ANDing in the switch matrix.
*********************************** FB1 ***********************************
Number of function block inputs used/remaining: 1/35
Number of signals used by logic mapping into function block: 1
Signal Total Imp Exp Unused Loc Pin Pin Pin
Name Pt Pt Pt Pt # Type Use
(unused) 0 0 0 5 FB1_1 (b)
(unused) 0 0 0 5 FB1_2 1 I/O I
(unused) 0 0 0 5 FB1_3 (b)
(unused) 0 0 0 5 FB1_4 (b)
LED 1 0 0 4 FB1_5 2 I/O O
(unused) 0 0 0 5 FB1_6 3 I/O
(unused) 0 0 0 5 FB1_7 (b)
(unused) 0 0 0 5 FB1_8 4 I/O
(unused) 0 0 0 5 FB1_9 5 GCK/I/O
(unused) 0 0 0 5 FB1_10 (b)
(unused) 0 0 0 5 FB1_11 6 GCK/I/O
(unused) 0 0 0 5 FB1_12 (b)
(unused) 0 0 0 5 FB1_13 (b)
(unused) 0 0 0 5 FB1_14 7 GCK/I/O
(unused) 0 0 0 5 FB1_15 8 I/O
(unused) 0 0 0 5 FB1_16 (b)
(unused) 0 0 0 5 FB1_17 9 I/O
(unused) 0 0 0 5 FB1_18 (b)
Signals Used by Logic in Function Block
1: PB
Signal 1 2 3 4 Signals FB
Name 0----+----0----+----0----+----0----+----0 Used Inputs
LED X....................................... 1 1
0----+----1----+----2----+----3----+----4
0 0 0 0
*********************************** FB2 ***********************************
Number of function block inputs used/remaining: 0/36
Number of signals used by logic mapping into function block: 0
(unused) 0 0 0 5 FB2_1 (b)
(unused) 0 0 0 5 FB2_2 35 I/O
(unused) 0 0 0 5 FB2_3 (b)
(unused) 0 0 0 5 FB2_4 (b)
(unused) 0 0 0 5 FB2_5 36 I/O
(unused) 0 0 0 5 FB2_6 37 I/O
(unused) 0 0 0 5 FB2_7 (b)
(unused) 0 0 0 5 FB2_8 38 I/O
(unused) 0 0 0 5 FB2_9 39 GSR/I/O
(unused) 0 0 0 5 FB2_10 (b)
(unused) 0 0 0 5 FB2_11 40 GTS/I/O
(unused) 0 0 0 5 FB2_12 (b)
(unused) 0 0 0 5 FB2_13 (b)
(unused) 0 0 0 5 FB2_14 42 GTS/I/O
(unused) 0 0 0 5 FB2_15 43 I/O
(unused) 0 0 0 5 FB2_16 (b)
(unused) 0 0 0 5 FB2_17 44 I/O
(unused) 0 0 0 5 FB2_18 (b)
*********************************** FB3 ***********************************
(unused) 0 0 0 5 FB3_1 (b)
(unused) 0 0 0 5 FB3_2 11 I/O
(unused) 0 0 0 5 FB3_3 (b)
(unused) 0 0 0 5 FB3_4 (b)
(unused) 0 0 0 5 FB3_5 12 I/O
(unused) 0 0 0 5 FB3_6 (b)
(unused) 0 0 0 5 FB3_7 (b)
(unused) 0 0 0 5 FB3_8 13 I/O
(unused) 0 0 0 5 FB3_9 14 I/O
(unused) 0 0 0 5 FB3_10 (b)
(unused) 0 0 0 5 FB3_11 18 I/O
(unused) 0 0 0 5 FB3_12 (b)
(unused) 0 0 0 5 FB3_13 (b)
(unused) 0 0 0 5 FB3_14 19 I/O
(unused) 0 0 0 5 FB3_15 20 I/O
(unused) 0 0 0 5 FB3_16 (b)
(unused) 0 0 0 5 FB3_17 22 I/O
(unused) 0 0 0 5 FB3_18 (b)
*********************************** FB4 ***********************************
(unused) 0 0 0 5 FB4_1 (b)
(unused) 0 0 0 5 FB4_2 24 I/O
(unused) 0 0 0 5 FB4_3 (b)
(unused) 0 0 0 5 FB4_4 (b)
(unused) 0 0 0 5 FB4_5 25 I/O
(unused) 0 0 0 5 FB4_6 (b)
(unused) 0 0 0 5 FB4_7 (b)
(unused) 0 0 0 5 FB4_8 26 I/O
(unused) 0 0 0 5 FB4_9 27 I/O
(unused) 0 0 0 5 FB4_10 (b)
(unused) 0 0 0 5 FB4_11 28 I/O
(unused) 0 0 0 5 FB4_12 (b)
(unused) 0 0 0 5 FB4_13 (b)
(unused) 0 0 0 5 FB4_14 29 I/O
(unused) 0 0 0 5 FB4_15 33 I/O
(unused) 0 0 0 5 FB4_16 (b)
(unused) 0 0 0 5 FB4_17 34 I/O
(unused) 0 0 0 5 FB4_18 (b)
******************************* Equations ********************************
********** Mapped Logic **********
LED <= NOT PB;
Register Legend:
FDCPE (Q,D,C,CLR,PRE);
FTCPE (Q,D,C,CLR,PRE);
LDCP (Q,D,G,CLR,PRE);
****************************** Device Pin Out *****************************
Device : XC9572-7-PC44
/6 5 4 3 2 1 44 43 42 41 40 \
| 7 39 |
| 8 38 |
| 9 37 |
| 10 36 |
| 11 XC9572-7-PC44 35 |
| 12 34 |
| 13 33 |
| 14 32 |
| 15 31 |
| 16 30 |
| 17 29 |
\ 18 19 20 21 22 23 24 25 26 27 28 /
Pin Signal Pin Signal
No. Name No. Name
1 PB 23 GND
2 LED 24 TIE
3 TIE 25 TIE
4 TIE 26 TIE
5 TIE 27 TIE
6 TIE 28 TIE
7 TIE 29 TIE
8 TIE 30 TDO
9 TIE 31 GND
10 GND 32 VCC
11 TIE 33 TIE
12 TIE 34 TIE
13 TIE 35 TIE
14 TIE 36 TIE
15 TDI 37 TIE
16 TMS 38 TIE
17 TCK 39 TIE
18 TIE 40 TIE
19 TIE 41 VCC
20 TIE 42 TIE
21 VCC 43 TIE
22 TIE 44 TIE
Legend : NC = Not Connected, unbonded pin
PGND = Unused I/O configured as additional Ground pin
TIE = Unused I/O floating -- must tie to VCC, GND or other signal
VCC = Dedicated Power Pin
GND = Dedicated Ground Pin
TDI = Test Data In, JTAG pin
TDO = Test Data Out, JTAG pin
TCK = Test Clock, JTAG pin
TMS = Test Mode Select, JTAG pin
PROHIBITED = User reserved pin
**************************** Compiler Options ****************************
Following is a list of all global compiler options used by the fitter run.
Device(s) Specified : xc9572-7-PC44
Optimization Method : SPEED
Multi-Level Logic Optimization : ON
Ignore Timing Specifications : OFF
Default Register Power Up Value : HIGH
Keep User Location Constraints : ON
What-You-See-Is-What-You-Get : OFF
Exhaustive Fitting : OFF
Keep Unused Inputs : OFF
Slew Rate : FAST
Power Mode : STD
Ground on Unused IOs : OFF
Global Clock Optimization : OFF
Global Set/Reset Optimization : OFF
Global Ouput Enable Optimization : OFF
FASTConnect/UIM optimzation : ON
Local Feedback : ON
Pin Feedback : ON
Input Limit : 36
Pterm Limit : 25
Hi,guzunty wrote:The only wiring diagram I have is a schematic for the daughter board I have coming in a few more days.
However, it's not too hard to wire from a table:
You also need to make JP15 on the underside of the board with a solder bridge, or you can instead connect Pin 26 of the Pi GPIO connector to FB4_MC5 if you built with a long pin GPIO header on the Guzunty.Code: Select all
LCD Module Guzunty D0 thru D15->FB1_2 thru FB3_9 (P1) CS->FB3_11 (P1) WR->FB3_14 (P2) RESET->FB3_15 (P2) CD (RS)->FB3_16 (P2) ENA (RD)->FB3_17 (P2)
sudo modprobe fbtft_device name=sainsmart32spifb
sudo modprobe sainsmart32fbCode: Select all
sudo modprobe fbtft_device name=sainsmart32spifb gpios=reset:4,dc:7 rotate=3 verbose=0 speed=32000000 fps=30
