arsenale
on off switch
Mon Jul 01, 2013 9:54 pm
I would like to be able to power on the raspberry pi using a switch.
There is no case that comes with a button, so I'm looking for a usb cable with a on - off switch
http://barbedwirebytecodebaconburger.co ... witch-mod/
Does anyone have a product to suggest?
I've seen many usb hubs, but they are expensive and made by shady brands, and generally only available on ebay!
thanks
sprinkmeier
Re: on off switch
Tue Jul 02, 2013 7:46 am
A switch like this would power off the Pi abrubpty. Eventually you'll nuke your SD card doing that...
Look for some of the projects here using the GPIO pins as power/reset buttons.
Pins 5 and 6 are ideal (one is ground, one is tied high, all you need is a pushbutton switch!)
arsenale
Re: on off switch
Tue Jul 02, 2013 8:41 am
Thanks for your clarification, anyway I alwasy use "sudo poweroff" command, so switching it off isn't a problem.
Do you think that in this cable, used only to power on the raspberry, there is something wrong?
piglet
Re: on off switch
Tue Jul 02, 2013 9:53 am
teeth_03
Re: on off switch
Tue Jul 02, 2013 10:50 am
That guy has to be making a killing for $20 bucks a pop. I'd be interested to see a premade case with one of those built in.
arsenale
Re: on off switch
Wed Jul 03, 2013 10:27 am
piglet wrote:This might be of interest to you: http://www.kickstarter.com/projects/131 ... spberry-pi
Yes, I knew about that, but I'm not intersted since it costs more thant the raspberry.... :-)
ChocolatePi
Re: on off switch
Thu Jul 04, 2013 1:11 pm
No, A is $25 and B is $35. Add the cost of the SD card, and it's around $6 more for each.... So no, it doesn't cost more than the Pi itself.
arsenale
Re: on off switch
Fri Jul 05, 2013 7:45 pm
We live in different countries.
NicoLoco
Re: on off switch
Sat Jul 06, 2013 2:36 pm
FYI I just posted a description of how I integrated a ON button in a basic element 14 case: http://www.raspberrypi.org/phpBB3/viewt ... 40&t=49213
shawaj
Re: on off switch
Sun Jul 28, 2013 2:31 pm
We have a kit available here - http://www.pi-supply.com/product/pi-sup ... er-switch/
This is also available open source as a schematic and gerber files both from http://www.pi-supply.com/downloads%20our%20website and from http://www.thingiverse.com/thing:79136%20Thingiverse
Hope that helps - let me know if you need any further help.
Cheers
Support The MagPi by purchasing printed copies from one of our retailers - http://themagpi.com/en/buy
Please share with anyone who is interested!
johnporter29
Re: on off switch
Sun Jul 28, 2013 4:58 pm
Just to clarify that I have just created a cable like the one in the above URL and it works a treat. You shutdown the PI before flicking the switch though.
-- John
Joe Schmoe
Re: on off switch
Sun Jul 28, 2013 5:09 pm
I wish to point out (again!) two salient facts:
1) If an on/off switch were really necessary, it'd have been included in the base hardware. This is pretty standard accepted fact in all things relating to computer hardware.
2) The need for an on-off switch is looking at the wrong end of the problem. What we need (and which I sincerely believe is possible; I'm a little surprised that no one has taken up my suggestion to implement and publicize a solution) is a version of the OS that doesn't self-destruct when power is removed. Basically, this would be done by making the OS read-only and/or in RAM.
RaspberryPaul
Re: on off switch
Wed Jul 31, 2013 2:13 am
Unfortunately, an ON/OFF switch with a software method for safely powering down the RPi really is needed, and isn't part of the package. Here's a schematic for a good soft power switch. You'll also need a Python script to recognize a GPIO interrupt, shut down processes, then issue a GPIO signal back to the hardware switch to turn off the power.
badrobot
Re: on off switch
Tue Aug 06, 2013 4:53 pm
I was lucky to have a spare remote control switch and that ia what I use with my Ras-Pi. My Ras-Pi is plugged in to the wall using a spare iPad charger. After "sudo-halt" command, I just click the switch and I am done.
It looks like this:
Gerrelt
Re: on off switch
Sun Aug 11, 2013 3:05 pm
Joe Schmoe wrote: 2) The need for an on-off switch is looking at the wrong end of the problem. What we need (and which I sincerely believe is possible; I'm a little surprised that no one has taken up my suggestion to implement and publicize a solution) is a version of the OS that doesn't self-destruct when power is removed. Basically, this would be done by making the OS read-only and/or in RAM.
Look at TinyCore, that does exacty what you describe.
my Raspberry Pi page: http://raspberry.gerrelt.nl
neilf
Re: on off switch
Sun Aug 11, 2013 8:08 pm
I added an onboard miniature on/off switch to all my boards as soon as I got them a year ago. There was no need for a cutout in the case as I mount my Pis in wafer cases so that I can get at all the GPIOs.
I couldn't imagine using a Pi without an on/off switch now - it's so convenient. Mind you, I mostly run RISC OS which is very easy and quick to shut down (two clicks :D ).
Wiring side of switch.
Cap side of switch
madnico
Tue Sep 17, 2013 1:50 pm
Hi
I made a ON/OFF circuit with flip-flop, transistor and triac. You push a button to start the Pi, and then you shutdown the Pi (by sudo halt command) the circuit detect low level trigger on a GPIO and switch off the power supply. You can see (in french) the project here: http://forum.madeinfr.org/topic/43/raspower/.
Sorry for my english.
Bye
ame
Re: on off switch
Wed Sep 25, 2013 6:36 am
I posted this already, but I think it's quite an elegant design.
http://www.mosaic-industries.com/embedd ... controller
madnico
Wed Sep 25, 2013 7:52 am
Yes your circuit is very elegant and you can shutdown the PI by long pressing the ON button. It's very usefull ! Good job.
Just one thing, in your circuit, the transformer still powered...not with mine ;) .
bullwinkle
Re: on off switch
Wed Sep 25, 2013 1:25 pm
ame wrote:I posted this already, but I think it's quite an elegant design.
Hello
i am interested in this solution. Do you have a breadboard photo of the setup you could share?
i am a a newbie on skematics so they are a little difficult to understand.
thanks
ame
Re: on off switch
Wed Sep 25, 2013 1:30 pm
Sorry, it's not my design. I found it and posted it here as I thought it might be useful to someone.
dan3008
Re: on off switch
Wed Sep 25, 2013 1:39 pm
neilf wrote:I added an onboard miniature on/off switch to all my boards as soon as I got them a year ago. There was no need for a cutout in the case as I mount my Pis in wafer cases so that I can get at all the GPIOs.
wow, I like it. you got instructions on how to attach that switch?
dan3008 wrote:Pays your money, takes your choice
SirLagz
Re: on off switch
Wed Sep 25, 2013 2:53 pm
I like that, nice and easy.
I'm assuming you had to cut something to make it do that ?
neilf
Re: on off switch
Sun Oct 06, 2013 8:13 pm
SirLagz wrote: I like that, nice and easy.
Yes, you have to cut one track. Rather, you have to scrape gently until you scratch just through the track and then stop. It's a multi-layer board so you have to proceed carefully, but it's not difficult if you're used to hacking micro boards.
You can just see the cut at the end of the red cable if you view the first shot full size. I did four of these switched boards - they take about an hour each to complete - and the resultant ease and convenience has been well worth it.
mahjongg
Re: on off switch
Sun Oct 06, 2013 10:37 pm
IMHO its not powering off the PI that destroys the card, so it has nothing to do with the OS, or in fact with any software, its actually the card itself that will damage its own flash filing system when you suddenly remove power while it happens to be writing to flash, or worse, shifting data around because of its "wear leveling" mechanisms. However if you can minimize the number of times data is actually written to the SD-card you can minimize the risk.
