Gary Littlemore
PiCE Case
Thu Jun 27, 2013 12:35 pm
Guys & Gals,
What are your thoughts on this PiCE the Pi Camera Enclosure? Could work well with the new camera features of RaspBMC
http://www.kickstarter.com/projects/182 ... e?ref=live
3b+, 2b, b+, b, Zero & Zero-W
phil_ed
Re: PiCE Case
Thu Jun 27, 2013 1:27 pm
Thanks Gary,
My name's Phil, i'm one of the guys here at Elson Designs who's helped design the PiCE and we would all be very grateful for your thoughts and ideas on the project.
I've added a few images of the PiCE. The first two are rendered.
PiCE with the lid removed showing the Daughter Board, Side Panels and Raspberry Pi
PiCESml LidRemoved.JPG (62.12 KiB) Viewed 11529 times
PiCE fully assembled showing the camera at the front.
PiCE showing the camera in our 3D printed prototype
cyrano
Re: PiCE Case
Thu Jun 27, 2013 5:51 pm
Whenever you think camera, attachment to tripods etc. springs to mind...
Gary Littlemore
Re: PiCE Case
Thu Jun 27, 2013 6:00 pm
I personally would like to see the camera turned round 90 degrees. So it's more to stand on the widest side of the case.
phil_ed
Re: PiCE Case
Fri Jun 28, 2013 7:13 am
Thanks guys, this is exactly what we're after and we're now designing in the ability to mount the PiCE onto a Tri-Pod. Having the camera in dual positions is a little more complicated, however we'll keep you informed with how we get on.
swheater
Re: PiCE Case
Sun Jun 30, 2013 12:02 am
If no camera is installer, and a microSD adapter is used, is there room for 6 AA batteries within the case?
phil_ed
Re: PiCE Case
Mon Jul 01, 2013 7:14 am
We're designing some modules which fit onto the rear of the PiCE. One of the designs will be to hold batteries so the PiCE can be deployed remotely and protect the Ethernet, USBs and Power from water ingress so you could use it outside. Below is an example showing just the ingress protection module.
At the moment there wouldn't be room inside the PiCE for 6AA batteries.
Rendered image of a rear module for IP protection for Ethernet, Power and USB, (not final design)
GordonTGopher
Re: PiCE Case
Mon Jul 01, 2013 12:06 pm
Looks good, to me 'remote' implies Wireless not Ethernet cable, any thoughts on getting round the screening issues that, I imagine, will come along with a metal case?
Gordon
Mortimer
Re: PiCE Case
Mon Jul 01, 2013 12:19 pm
GordonTGopher wrote:Looks good, to me 'remote' implies Wireless not Ethernet cable, any thoughts on getting round the screening issues that, I imagine, will come along with a metal case?
Gordon
In my line of business 'remote' implies that it is remote from the operator's normal working position. For example, an imaging processor that is up the mast alongside the camera it is connected to. The operator is in a building at ground level. The only way the operator can use the imaging processor is 'remotely' via something like VNC or RDP. The nature of the connection in between is immaterial, in fact we prefer cables.
The purpose of a little toe is to ensure you keep your furniture in the right place.
phil_ed
Re: PiCE Case
Mon Jul 01, 2013 1:05 pm
Gordon
Yes, we assumed Wi-fi, 3G, 4G etc so the modules we're designing will be made from plastics so they're RF transparent.
RaTTuS
Contact: Twitter YouTube
Re: PiCE Case
Mon Jul 01, 2013 1:20 pm
umm
has it got a camera mount threaded hole ? because that would be awesome for a tripod mount
Covfefe
phil_ed
Re: PiCE Case
Mon Jul 01, 2013 1:25 pm
It certainly has :) (1/4-20 UNC)
RaTTuS
Re: PiCE Case
Mon Jul 01, 2013 1:27 pm
backed!
Covfefe
phil_ed
Re: PiCE Case
Mon Jul 01, 2013 1:39 pm
That's awesome news. Thanks for supporting the PiCE, it's greatly appreciated :D
RaTTuS
Re: PiCE Case
Mon Jul 01, 2013 1:51 pm
And Tweeted ;-p ... I'm going to have to stop looking though kickstarter ....;-p
hope you manage to get it funded ...
Covfefe
toxibunny
Re: PiCE Case
Mon Jul 01, 2013 2:23 pm
It would be much improved with a button or two - one for 'take snapshot' and one for 'start/stop recording', and maybe an indicator light. I know the case is not intended to turn the pi into a standalone camera (otherwise it'd have a battery pack as well), but a couple of buttons would come in very handy...
Also, if there's space (which judging by the 3d printed prototype, there is), a simple viewfinder would be easy to implement - something like a hole straight through, or maybe one with a smallish square hole on one side going to a larger one on the other side with a circle and a crosshair or something like that maybe - so you can look through and make sure it's pointing in the right direction without needing a screen.
*looks back at thread* ah, you've got the camera placement in a 'video camera' type placement, so wouldn't fit with my viewfinder idea. Forget that then :P The button might still be nice though.
Just a couple of thoughts. :)
note: I may or may not know what I'm talking about...
toxibunny
Re: PiCE Case
Mon Jul 01, 2013 2:25 pm
...it would be cool though if someone made a proper raspberry pi point and shoot camera. I expect one will appear on hackaday sometime in the coming months...
phil_ed
Re: PiCE Case
Mon Jul 01, 2013 3:20 pm
That's a tricky one. While we could modify the design to add in a couple of buttons we want to keep the design as generic as we can. Adding buttons would also add a cost to the design (in terms of tooling complexity and actual buttons) and increase other risks like security, water ingress etc.
What you could do, (I'm quite happy to write a tutorial once we're funded) is drill a couple of holes for some buttons on one of the side panels and wire them to the GPIO pins. Write a little script to listen to those pins and take stills / video based on their state. The PiCE already has the camera LED on the front so you'd also be able to tell when the camera was recording / taking stills.
I hope this helps.
GordonTGopher
Re: PiCE Case
Mon Jul 01, 2013 3:48 pm
toxibunny wrote:...it would be cool though if someone made a proper raspberry pi point and shoot camera. I expect one will appear on hackaday sometime in the coming months...
Depends on your definition of proper.http://raspi.tv/2013/raspicamcorder-2-s ... capability
Gordon
Gary Littlemore
Re: PiCE Case
Tue Jul 02, 2013 12:06 pm
RaTTuS wrote:I'm going to have to stop looking though kickstarter ....;-p
I'm the same too, I've backed 3 projects now and think back "Why did I need one of them." But I would use the PiCE, but I already have a milled aluminium case that cost me a small fortune to have it shipped in from the USA.
RaTTuS
Re: PiCE Case
Tue Jul 09, 2013 10:59 am
this deffo needs to get more support
I would like to see this get funded
come one peoples - you know you want one..... ;)
Covfefe
piglet
Re: PiCE Case
Tue Jul 09, 2013 11:09 am
Is it just me showing my age, or did anyone else see the image and think "Space 1999"?
RaTTuS
Re: PiCE Case
Tue Jul 09, 2013 11:13 am
piglet wrote:Image
It's your age ;-P
https://www.google.co.uk/search?q=space ... 8&bih=1011
Covfefe
phil_ed
Re: PiCE Case
Tue Jul 09, 2013 11:26 am
piglet wrote:Image
You've just made our day! It'd be great to put some red LED's in those holes!
GordonTGopher
Re: PiCE Case
Tue Jul 09, 2013 7:48 pm
RaTTuS wrote:this deffo needs to get more support
I agree, I've backed it and hope it succeeds.
Gordon
