Hi, I'd like to load side b of a tape image using the datasette controls (rewind and start) but it's not working.
I've tested this using Flimbo's Quest, and these controls work in Windows to load and run the game, but not in retropie.
In Windows (x64.exe), I've attached the side b file. I then click rewind and start, and side b loads, and I can play the game. In retropie, nothing happens when I click start.
Any help would be much appreciated!
Re: C64 emulator
Try this version for the Raspberry Pi 2:
https://drive.google.com/open?id=0B1BUn ... W1LZlh2OWs
Unzip, move the vice-directory to /user/local/lib (mv ./vice /usr/local/lib) and move the executable to /usr/local/bin (mv ./x64 /usr/local/bin)
Start with x64.
Start with x64.
Re: C64 emulator
I have to get this old thread back up, because I have a tearing problem using sdlui with vice 2.4 as mentioned here:
viewtopic.php?f=78&t=69353&sid=5284e35c ... 6d8e8a1f39
As far as I understood, the modifications posted here could be the solution to this problem as the patch makes vice use openGL?
Re: C64 emulator
Does anyone have an archive of mod that AreaScout did of vice-emu-rpi-2.3.21.zip ? The link is dead and I can't find it stored anywhere else.
