Below is a mish-mash from a few hours of pondering PI:
With the case I need to make for the RP(old hard drive cases might be my foundation) I could add the powered USB hub to the case and possibly the fans from the 360 intercooler(needs on/off switch).
I just need to figure out how to power the fans.....try an external power source or use the powered USB hub for the fans........
Case ideas - Various objects around the house (modify) or build from of scratch...was thinking of old electronics for the various objects (vcrs, old hard drives, old cd/dvd drives,)
Outer ideas - Try using LED lights that can be wired into a speaker system. The LEDs will pulse to the beat of the audio......make a switch to turn this feature on and off for use during the day (not needlessly using the lights,prevent distraction) Must look into How to make this happen!!
If the any of the previous suggestions are possible, add a spot on the outside of the case if my Belkin B/G USB dongle works in one of the OS choices for in-car RP awesomeness!!! .....
Recycling old Electronics for RP's sake -
Would using an GBA screen or the 2 NDS screens (regular screen/touch screen) work on the RP through the RCA port????
I Was thinking of this as a basic screen for my RP to use, like the mini screens a printer has....need more info
I have old printers, scanners laying in storage
I also have a non-operational portable Vtech edu-game system(it was dropped, not sure if an internal component went, preventing the video from working or the screen died itself)
I might still have a laptop screen from an old P3 laptop
Gaming ideas - I have an old xbox controller that I already wired to work on Windows in test mode.......what would RP think??
