Most of the DIY plans I've found are very similar or the same (with a few variations) and are built on regular prototyping boards. It's been a while since I've had many EE courses, so due to those variations and the layout that I'd like to build on a Radio Shack 276-159B board, I have a couple of questions.
Here is a sample circuit I found on SoDoItYourself:
http://i40.tinypic.com/s33a11.jpg
And a different one from X-Box Scene:
http://i41.tinypic.com/30hlclf.jpg
These are mostly the same except that the one for the X-Box LiteOn drive does not seem to be interested in the Rx side and the SDIY circuit includes a connection between the +3.3v and GND with a 10uF cap on it.
I think I've translated the circuit correctly to the IC board from the shack below (rendered in lovely MS Paint). A) would someone like to error check it to make sure I didn't foul it up and B) what is the deal with the extra connection with the cap (shown in yellow). Is this part of the circuit optional?
http://i41.tinypic.com/20tklc7.jpg
ETA: Also, are polarized caps necessary?
ETA2: According to Table 2 in the Maxim data sheet, should I be using 0.1uF caps instead of 1uF? http://datasheets.maximintegrated.com/e ... AX3241.pdf
