rgmward
Re: Cases for the Raspberry Pi
Thu Feb 16, 2012 1:05 pm
just read an interesting article over on theregister where there is a company created a material that is paper based that can be used for pc cases.
sounds really interesting that the raspberry pi case could be recylcable and environmentally sound - something for the foundation to look at?
if it is paper - should allow for customisation in design/painting
http://www.reghardware.com/201.....rom_paper/
mgmt_idiot
Thu Feb 16, 2012 1:55 pm
You beat me to it
spamel
Thu Feb 16, 2012 3:07 pm
I might just blu-tac mine to the desk!
abishur
Thu Feb 16, 2012 3:09 pm
Legos are getting my attention right now
Dear forum: Play nice ;-)
nhslzt
Thu Feb 16, 2012 11:02 pm
Hello!
I'm working a nice finger-jointed and laser-cut wooden case, please contact me if interested! Small customizations will be possible. I still have to set a price but it will be cheaper than a 3d printed one.
In the next days all info will be posted here:
http://www.etsy.com/listing/93.....er-jointed
spamel
Thu Feb 16, 2012 11:10 pm
I have some Star Wars lego knocking about some place. That'd be cool if |I could incorporate the pi into one of the builds!
JamieR
Fri Feb 17, 2012 12:25 am
nhslzt said:
Hello!
A wooden case sounds very cool, be sure to post a picture of your first one, i'd love to see it.
flipdewaf
Fri Feb 17, 2012 9:37 am
I think I'll make a case from card to see if it works and then break out the grinder and make it from stainless (must also buy own welder).
Fred
optimus
Fri Feb 17, 2012 1:11 pm
At this stage my plan is to stick embed mine inside a gutted 5'1/4" floppy.
Really like the r2d2 money box idea though, that's brilliant. I wonder if there's any suitable transformer ones...
archsaddler
Fri Feb 17, 2012 1:15 pm
Ive seen an Allspark usb hub somewhere
optimus
Fri Feb 17, 2012 1:27 pm
Pfft, new transformers aren't real transformers!
jon404
Fri Feb 17, 2012 1:52 pm
Pi Fighter surely is the obvious choice!
optimus
Fri Feb 17, 2012 3:37 pm
... Or an Pi x-wing bramble!
SirWeasel
Sun Feb 19, 2012 7:24 pm
Does anybody know what the operating temperatures would be??
I was thinking about putting together a casing using Polymorph thermoplastic but it melts at 60deg. So the last thing I want to do is lovingly craft a casing to go on the much anticipated R-Pi to then melt the casing on to the unit.
Alternatively I have been toying with the idea of using EVA foam which has better temp properties and more likely to be available in schools.
Thoughts?
JJD
Sun Feb 19, 2012 7:38 pm
Good question S.W., I have been wondering the very same. The answer is probably somewhere on the forum or wiki. I hope…
Okay, much better now: http://www.raspberrypi.org/for.....emperature
Now that I know, I can do a certain type of build without any worries. It's hot where I live and very humid. Our summers are even worse.
debabrata
Mon Feb 20, 2012 7:49 pm
Will this one work as a box for the Pi?
http://www1.conrad.nl/fas6/fh......w%3Dsearch
Its priced well, and, of course you have do the side cutting part yourself.
Retroman
Mon Feb 20, 2012 8:04 pm
Here"s a revised video of the 3D model I"m using to plan everything(old model was 1.3mm to short in length and 1.3mm to wide for some reason).
Link to the project:
http://bit.ly/RasPiBoy
debabrata
Mon Feb 20, 2012 9:52 pm
And I got another one, and this one looks better, but is a bot more costly and a bit more bigger but I guess will fit in the Pi well.
REVOLTEC ACRYLIC CASE - 2,5"
http://www.revoltec.com.ua/pro...../rs034.htm
http://www.h-online.com/pricei...../eu/183135
debabrata
Mon Feb 20, 2012 10:03 pm
WOW....I seem to be very lucky...found another "maybe" case for the Pi (and the price is also right @ £5.00 I think) and both are 3.5 inch floppy cases (didn't knew they were still around):
http://www.amazon.co.uk/dp/B00.....nkCode=asn
http://www.airetechit.co.uk/e-.....livemode=1
debabrata
Mon Feb 20, 2012 10:09 pm
And, I think I got the ultimate one yet! (in terms of ease of use and price @£2.99 Inc VAT )
http://www.misco.co.uk/product.....s-_-110845
Will this last one fit the Pi I guess??
MINKIN2
Mon Feb 20, 2012 10:55 pm
jawhn said:
Well, I am hoping to fit mine into an old Atari 2600 cartridge... I have seen several other people had the same idea.
I even designed a label for it. Whaddya think? I'm planning on printing a few of these up soon...
Loving the CX-2601 Combat cart design mate Have you made a top label too?
devnull
Tue Feb 21, 2012 1:02 am
I've searched the wiki and website and can't seemed to find a mechanical drawing of the board showing dimensions to the various connectors.
I'm sure there must be one, can someone point me in the right direction ??
Cheers
> /dev/null 2>&1
Jongoleur
Location: O'erlooking the sea, and all those effin windfarms...
Tue Feb 21, 2012 9:42 am
I was going to make a brass and mahogany ply case for my Pi, but it looks like I won't have the time...  So when I get my first (which batch I wonder?) its going to have a printed thick paper outer with reinforcing card inserts glued inside for stiffness and to hold the board in place.
When I get another, I may make a spiffy case!
I'm just a bouncer, splatterers do it with more force.....
mobeyduck
Tue Feb 21, 2012 10:47 am
Cheers
You need to increase your searching skills young padawan.
http://www.raspberrypi.org/for.....nical-data
there even was a front-page post that linked to it and to a highly detailed drawing the last post on the first page in that thread has a sketch-up model
devnull
Tue Feb 21, 2012 11:14 am
Thanks very much.
Just to be sure I was not dreaming this morning when I posted, I just searched again for Mechanical Drawing in the forums and didn't see anything on the first 4 pages of threads.
Is anyone able to advise if / when we might get an 'official' mechanical drawing ?
Thanks again.
> /dev/null 2>&1
