Hello, guy, pls help on my annoying issue:
I use to use wheezy.
Everything is fine for, using the hdmi video out.
But as soon as i switch to composite video ot by editing config.txt (hdmi_ignore_hotplug=1) the colors are all wrong for some issue. i cant get into it so far.
it cant be a hardware thing because it works well as i use another sd card with xbian. There the colors are correct on tv headend.
I had the same issue one or two weeks ago, as i used openelec on my 2nd sd card. after some reboot the tv headend screen showed the same wrong colors as now. i couldnt solve the problem so i installed xbian which worked well by now.
its annoying i cant switch my wheezy installation to the tv now, because of the wrong colors.
ive played around with almost all settings in config.txt but nothing seems to affect that issue. pls help.
