wellsm89
Apple Cinema DIsplay
Thu Jan 31, 2013 9:38 pm
Has anyone had any luck using an Apple Cinema Display connected to a raspberry pi? There are a few forum posts but no one has an answer,
Cheers
lude
Re: Apple Cinema DIsplay
Fri Feb 01, 2013 7:11 pm
No reason it shouldn't work. You just need a male HDMI to Female DVI adapter to plug the screen in.
threecee
Thu Feb 07, 2013 4:48 pm
anyone have any luck? i've tried many different combinations of settings in the /boot/config.txt file for HDMI options, but no luck. the display continually flashes it's status LED, indicating unsupported HDMI format.
elatllat
Thu Feb 07, 2013 5:42 pm
The 2560x1440 display will work off a 1920x1280 signal (my mac offers it as an option) but I'm not sure what other options it needs...maybe related:
https://plus.google.com/u/0/10215069322 ... QsCY7ErAL4
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
threecee
Thu Feb 07, 2013 5:52 pm
unfortunately, i have a *very* old apple cinema display: circa 200 model M8149 (which doesn't even show up on apple's support site).
BarryLegg
Mon Apr 01, 2013 7:34 am
Hi there, I can shed some light on this;
If you have a the older style Cinema Display (pre-Thunderbolt) and the status light gives 3 flashes then a pause; it's not going to work.
That display only accepts a digital signals. You need a separate breakout box to convert the analogue signals from the Pi to digital in order to work with this display.
These devices do exist, but they're pricey. I saw someone use one to get an Xbox to work with this display. I believe a company called Blackmagic make just such a device.
The newer Thunderbolt displays will accept analogue signals, but they cost 32 times more than the computer you're going to be running it with.
