I am a product engineer and I would really like to make a custom case. Problem is that I have yet to come across any solid models of the RPI. And I'm sure this is for good reason, with RPI not wanting these out in the wild per-say.
If you guys would be able to send them my way privately as an .iges or .stl file I will then be able to open it in solidworks and go from there. This would be the best way for me to make my case so that I do not need to re-create the RPI in solidworks when I get mine. Having access to the actual model will make the case the most accurate as well.
If I need to sign an NDA in order for this to happen, I will gladly sign one.
Please get back to me on this, as I would like to get started on this right away!
Thanks,
Bryant
