kevleyski
Re: Sinclair ZX Spectrum (rubber keys) Pi retro fit
Tue Feb 14, 2012 8:08 pm
I have an old ZX Spectrum 48K I"m retro fitting with Raspberry Pi
Goal is to not break the original board (much) and write a USB HID Linux driver for the original rubber membrane keyboard and fit HDMI out ext without anything dangling out the EDGE connector if physically possible.
Questions, what do we know about the ZX keyboard -> UART/USB, or is my only real option to take a generic USB HID keyboard and mechanical retro fit tot the micro switches?
Also Kempston mouse, anyone know about that? (and does anyone have one) I guess could use Sinclair joystick (which maps the the keyboard) and create onscreen cursor with Qt for example...
Kev
Paul Webster
Contact: Twitter
Tue Feb 14, 2012 9:35 pm
It pre-dates USB and looks to be relatively tricky to do.
This old write-up should help
http://www.users.globalnet.co......r01_58.htm
plugwash
Tue Feb 14, 2012 10:25 pm
I don't have specific experience of the specturum but tt should be possible to program a USB PIC to scan pretty much any keyboard matrix and convert the results into PC keyboard scancodes for feeding to a PC.
Lynbarn
Tue Feb 14, 2012 10:54 pm
Also Kempston mouse, anyone know about that? (and does anyone have one) I guess could use Sinclair joystick (which maps the the keyboard) and create onscreen cursor with Qt for example…
Kev
I'm not quite sure WHY you would want to do this (the first peripheral I got for my speccy was a metal-cased proper keyboard) but APEM and similar manufacturers will probably be able to manufacture a suitable membrane keyboard, although at what cost I do not know!
If you could be a bit more flexible (excuse pun) then maybe something like one of these on eBay would fit the bill (and with a bit of trimming, perhaps even the Spectrum case?)
bigand
Wed Feb 15, 2012 8:41 am
If you have a look here:
http://www.flickr.com/photos/z.....543421081/
This guy has got the original working through a hacked usb keyboard.
Edit: I think it might be one of those listed in the ebay link above.
mccp
Wed Feb 15, 2012 11:06 am
Awesome!
Casalor
Wed Feb 15, 2012 11:29 am
It's entirely do-able.
For my initial Pi project, I've taken an old Amstrad CPC 6128 and hacked/soldered the connectors to a usb interface ripped out of a flexi keyboard (as did the Spectrum guy above). I used xev and xmodmap to create new mappings. Luckily for me the Amstrad uses a 8 x 10 array which fitted nicely.
I count this as the most difficult thing about my Pi 6128 case mod. Everything else is just gluing and cutting.
stefan72
Thu Feb 16, 2012 10:26 am
Hello, I thougt about to add the Raspberry PI in to a working C64.
With the keyrah C64 Keyboardkonverter
it must be possible to switch between the both Computers. Actually the both can use the same TV Screen.
ady69
Thu Mar 15, 2012 9:12 pm
Hi this might be of interest.
Its based on the beagleboard but the guy's modded his zx spec rubber keyboard.
Hope this helps.
http://www.retrothing.com/2009.....linux.html
Second link shows the full mod.
monk3yfurr
Sun May 13, 2012 3:35 pm
If anyones interested, I've just written some code for the arduino that scans the data lines of a ZX spectrum (rubber keyboard) to determine which key has been pressed. This could then be used with an arduino duo (reflashed for HID use) to turn the keyboard into a standard USB one. Alternatively there's a library written for the PI's GPIO that should be compatible and could be used to send the keys directly to the x-window (without the need of an arduino).
andrewjoy
Mon May 14, 2012 1:00 pm
this may be of use to you
http://deskthority.net/workshop-f7/all- ... t2340.html
my feeling is the best way to do it would be to use the existing matrix and make your own controller
unless anyone knows what scancode set it uses then a converter could be made
monk3yfurr
Tue May 15, 2012 3:15 pm
Thats what i'm using the arduino for, a replacement controller which makes use of the existing keyboard matrix. The original matrix is wired into the arduino and i've currently got the keys being pressed output to a hyperterminal window. Next step is to setup the arduino as a HID and we have a working usb keyboard.
ryandigweed
Thu Jul 12, 2012 10:51 am
I was thinking of doing the same, but was unsure how to go about this one :(
qlue
Sun Sep 09, 2012 12:44 am
Perhaps this is a silly question, but why not just use the GPIO lines?
https://github.com/cpswan/Python/blob/m ... io-kbrd.py
edit:
Here is the post I was actually looking to link to.
http://www.raspberrypi.org/phpBB3/viewt ... =50&t=8842
andrewhannay
Thu Mar 14, 2013 4:02 pm
Just scan the keyboard using the IO pins on the RPi.
I believe the Spectrum used a keyboard matrix of 8 rows x 5 columns.
That's by far the easiest way to do it, not messing around with all that complicated USB stuff.
But, hang on, that means you need to write a driver then - oh dear, damn these complicated graphical RTOS's.
Andrew
