Jawloms
Re: Firewall
Fri Feb 10, 2012 9:46 pm
I have tried searching for this and haven't found anything, but apologies if I've just missed it.  I know that Smoothwall won't go on the pi (unless someone ports it), but is there an alternative?
Thank you
Stuart
bredman
Re: Firewall
Fri Feb 10, 2012 9:55 pm
Your problem may be that there are too many alternatives.
Almost every Linux firewall GUI is just a front-end for iptables.
See here for more info on Debian, but the situation is very similar for all distributions.
http://wiki.debian.org/Firewalls
error404
Re: Firewall
Sat Feb 11, 2012 12:04 am
First of all, if you're after an actual dedicated firewall, the Raspberry Pi hardware is not very suitable.
Not many dedicated firewall distributions are likely to build for ARM. Most of them are designed around relatively 'large' systems. OpenWRT is fairly likely to get a port IMO, as it's pretty suitable for other embedded tasks that Pi will be good at and already runs on some other ARM-based devices, so you could use that. Or you could just roll something yourself. I happen to like the Shorewall set of iptables scripts.
cnxsoft
Re: Firewall
Sat Feb 11, 2012 4:22 am
You could setup the R-Pi to be a headless Linux firewall using iptables. http://www.linuxhomenetworking.....g_iptables
I'm not so sure about the performance though.
bredman
Re: Firewall
Sat Feb 11, 2012 8:54 am
When building a firewall, remember that the RPi has only one ethernet port. This means that the RPi must be configured as a router, not a switch.
What does this mean to you? It means that the equipment you are trying to protect (for example your PC) is still physically wired to the internet. The only reason it would pass its traffic through the RPi firewall is because it is told to.
In this scenario, it is very easy for a user or for malicious code to bypass your firewall.
So the hard truth is, if you want to build a proper firewall, you build it on a box which has two ethernet ports. This means that traffic must pass through the firewall.
For the purists, I know that you could lock down your modem to only accept traffic to/from your firewall, but most modems do not allow this level of control. If the modem allows this level of control, the modem probably includes a fancy firewall also.
cnxsoft
Re: Firewall
Sat Feb 11, 2012 8:57 am
Alternatively he could use a USB Wifi Dongle and configure the R-Pi has a router. All clients would have to support WiFi however.
Jawloms
Re: Firewall
Sat Feb 11, 2012 10:10 am
That's pretty much what I was thinking. Speed won't be an issue as the bottleneck will be the Internet connection itself.
Thank you to everyone else.  I have a static IP address for my broadband and what I wanted was to connect the Pi to my Internet router, then be configurable so that I can not only decide what goes out, but do some basic filtering for the kids (as I don't like Windows Family Filter) and also access my home network from the outside world, either via ftp, RDP, HTTP and anything else I can come up with.  All the other devices will connect to the Pi via wireless so presumably it would need to act as an AP?
bredman
Re: Firewall
Sat Feb 11, 2012 10:41 am
It can be very difficult to find a WiFi USB device which is capable of working in AP mode.
Your RPi can act as a normal WiFi station if you have an AP already available. You would need to disconnect the ethernet port of your AP. You may also need to configure your AP, set the RPi as its gateway device.
Adding a WiFi access does get around my concerns above related to having only one network interface.
broken pipe
Re: Firewall
Sat Feb 11, 2012 11:44 am
you can nearly cover every scenario with iptables. for a wifi access point 'hostapd' is recommandable and you also need a wifi device which works in monitor mode.
offtopic: go and get some cheap router which runs openwrt/ddwrt, flash it, configure it and you're fine ...
tr1ck5t3r
Re: Firewall
Sat Feb 11, 2012 5:24 pm
Thank you
Stuart
This might be useful ie pfSense.org an extremely capable firewall with lots of addons including things like Snort.org which is used by some Govt's to protect their infrastructure.
http://www.raspberrypi.org/for.....-4/#p40413
drgeoff
Re: Firewall
Sat Feb 11, 2012 5:33 pm
Or a USB to ethernet adapter.
tr1ck5t3r
Re: Firewall
Sat Feb 11, 2012 7:18 pm
EDIT: I should add you wont be able to run Snort on the Pi becuase it uses more memory than is available on the PI, but for firewall, DHCP and other routing tasks it should be ok.
error404
Re: Firewall
Sun Feb 12, 2012 12:21 am
pfSense is by far my favourite router for small to medium sized setups. But a port is, at best, a long way off. First a FreeBSD port, then someone over at pfSense to bother porting it to this RPi, which is not really a great router platform in the first place. Considering they haven't even ported it to some of the larger MIPS routers out there that actually have appropriate hardware, I'd say chances are pretty slim.
RaTTuS
Contact: Twitter YouTube
Re: Firewall
Sun Feb 12, 2012 11:16 am
IPCop may be worth a look,
they build it from LFS, so changing to an arm build may be easy [sic]
Covfefe
tr1ck5t3r
Re: Firewall
Sun Feb 12, 2012 11:27 am
Apologies, I thought I'd seen references to Linux on their site but obviously not the case upon closer inspection.
Jawloms
Re: Firewall
Sun Feb 12, 2012 11:39 am
Thank you to all for your input.  I certainly have plenty of options to look in to now
fusiooon
Re: Firewall
Tue May 08, 2012 1:47 pm
I don't think you need 2 adapters, you could theoretically make the LAN port a trunk port and use tagged VLANs to separate traffic. Then the Pi could act as a router between the 2 VLANs. Obviously you will also need a switch that supports VLAN tagging. One VLAN could be connected to the Internet, the other to the local network. Hope the interface supports VLANs.
In my opinion using Snort with iptables would be ideal, not sure if the hardware is sufficient for snort to work satisfactory though. Will try it when it finally arrives.
Arne.F
Re: Firewall
Tue May 22, 2012 11:21 pm
Today i have released a first testing-image of IPFire for Raspberry Pi.
IPFire is a IPCop fork which is also available for ARM.
http://planet.ipfire.org/post/ipfire-on ... first-test
I have tested with a second USB Ethernet dongle yet. Wireless AP with a Ralink RT73 USB Dongle should also work but I have not tested this yet.
But keep in mind that only basic features work because the low computing power of the RPi.
Arne
chewchew
full or partial Firewall appliance on raspberry pi
Sun Feb 24, 2013 5:43 pm
error404 wrote:pfSense is by far my favourite router for small to medium sized setups
As a novice to diy firewall appliances I would appreciate your thumbnail comparison of IPfire v pfSense [v IPcop (mentioned a few posts down)]. The request is RPi topical as i have some parent/child concerns about RPi as interweb device given ease of swapping out SD. One of the two or both should allow rules requiring use of particular NS resolver but articles on the topic presuppose familiarity I lack. Searching the interweb has become irksome with high volumes of spam results and "articles" which exist to churn ads.
fusiooon wrote: make the LAN port a trunk port and use tagged VLANs to separate traffic.
I'd like to learn more about that. If you have some URLs up your bookmark sleeve that'd be great.
Arne.F wrote:IPFire is a IPCop fork which is also available for ARM.
ohh. Nonetheless I would like to glean a bit of wisdom.
Arne.F wrote:Today i have released a first testing-image of IPFire for Raspberry Pi.
That following this harsh critique is inspiring:
http://planet.ipfire.org/post/the-raspberry-pi-dilemma (April 14)
- SoC that is working on the RPi board is old. I mean really ooooold.
- not make benefit of a fast GPU
- LAN ports are connected to the USB bus which causes very poor performance.
And wow, arne.f, continues chugging away at RPi IPfire:
http://planet.ipfire.org/user/arne_f
though I cannot determine if the feb posts are 2012 or 2013 with lack of year in the post timestamps
I'm going to need a larger stack of SD cards! Mine is merely six tall now.
arne_f,
if your project is still active would you consider also releasing it in BerryBoot ready format. I haven't been able to BBoot convert an image yet.
Raspberry Pi AS Jabber server
APratham
Contact: Facebook Google+ Twitter
Re: Firewall
Tue Nov 28, 2017 2:23 pm
Hi!
I believe I am acrually quite a novice to Linux and coding, nevertheless I have got this project I will be finishing over the due course of time in the coming year. We want to connect the Pi to the internet and enable ssh access. I know that means we are going to compromise on a lot of security. A few of the posts here concern on lots of commercial firewalls which we may not require. What we require is some amount of basic protection so that someone on the internet looking at our Pi Cluster which is running image processing must not be able to host basic attacks on the RPi. So can I have a basic firewall using iptables on the RPi?
B.Goode
Re: Firewall
Tue Nov 28, 2017 3:03 pm
The thread you have resurrected is nearly 6 years old.
Maybe it would be better to Report your own post to a Moderator and ask for it to be raised as a new topic.
On the one hand, the basic principles of Linux and network security are still pretty much the same.
But on the other hand the recommended and supported Raspbian Operating System has been superseded twice in the intervening period, so some specific details may well be different.
There is a guide published by the Raspberry Pi Foundation that might kickstart your thinking: https://www.raspberrypi.org/documentati ... ecurity.md
