NigelRex
Re: Raspberry Pi as an OPC Server
Fri Feb 03, 2012 11:16 am
Has anyone considered an R-Pi as an OPC server for data collection? Using the GPIO connections it would make an interesting data capture device that could then feed data into any number of standard applications for analysis and storage.
I'm thinking here about higher level education, from 16 years upwards into under graduate work maybe?
clayauld
Thu Oct 25, 2012 6:46 am
Yes, I am thinking of setting up the R Pi as an OPC Server. My usage would be for electrical metering and the data would be stored and manipulated on the OPC server. I have already done this running and OPC server on Windows, but I am looking for a good way to integrate it onto a small system like the R Pi. Any ideas?
cjpanici
Tue Oct 30, 2012 3:23 pm
Yes, I am interested in this. Please keep me posted on further development.
TonyD
Wed Oct 31, 2012 10:28 am
Sounds interesting :-)
What OPC server were you thinking of running on the RPi? I've only used them on Windows and not used any for Linux.
Tony
NevergoldMel
Fri Nov 15, 2013 4:19 am
That could be really useful.
nasfald
Tue May 20, 2014 9:40 am
Even if this is an old topic, others may look for the same solution, as I did.
OPC used to be a Windows standard, but it has changed and a lot of tools,
including OPC server, exist for Linux based system. You could find much of
those here :
http://opcconnect.com/
Unfortunatly, most of them are propriatary (all of OPC and SDK there, are).
But I found this :
http://www.openopcua.org/
I didn't test it yet, but Rasperry Pi compatibility is specify, and it is
supported by a lot of big companies.
ranpitime
Mon Feb 01, 2016 6:47 pm
you could use the CODESYS plc on raspberry, this gives you the possibility to access symbols by a OPC Client.
->on the Pi plc an OPCUA Server is embedded in the plc runtime.
BR
ranpitime
Anugerah Nuri Satria
Tue Mar 13, 2018 11:14 am
I have problems, when i try run this programs, at QX output "merah_0" has "TRUE" value in client, and i try to connect with raspi, but at gpio raspi can't switch on the lamp.
I use opc ua client and server to communicate all of them and used 4diac to build a program
Tue Mar 13, 2018 11:19 am
I have a problem when i try to build a simply project with raspberry using opc ua protocol.
when i try to run a program, at the output "merah_0" is true, but at raspi client can't switch on the lamp who i use to be output
