Terrariachest
Raspberry Pi buttons
Sat Aug 08, 2020 4:25 pm
Is there any way I can use a physical button to input a command into the terminal? Any help is deeply appreciated
thagrol
Re: Raspberry Pi buttons
Sat Aug 08, 2020 5:35 pm
Not directly.
You can write a program that waits for a button press then runs your command but there are a bunch of things you need to take into consideration. Not least of which are:
  • Whether your command needs to output something
  • Whether it needs input from the user
  • How you're going to start this program and when
Terrariachest
Sat Aug 08, 2020 5:52 pm
Not directly.
Thank you for giving me an answer, it just needs to activate bluetooth by running sudo bluetoothctl. It's a bluetooth speaker project. Bluetooth doesn't automatically power on during boot for some reason.
thagrol
Sat Aug 08, 2020 6:13 pm
In which case, I'd look into using python and gpiozero. There are examples for butons in gpiozer here: https://gpiozero.readthedocs.io/en/stab ... tml#button
You can use the os or subprocess modules to make the call to bluetoothctl.
