Hi all,
I have been experimenting with a MAX7219CNG and 7 Segment displays and had some success. I am now scaling it up and made a custom 6 Digit 7 Seg prototype using vero board (strip board) - see attachement and 5mm LED's (2 in Parallel per seg). I worked out that the LED Segments of a standard 7 Segment Display are around 1.8V - 30mA(Measured at 20mA). The 5mm White LED's are in parallel ( 3.2V 20mA) Using the attached circuit diagram I have set Rset at 27K (I tried higher and lower but it didnt seem to change the current, or brightness much), although i know the rule of thumb seems to be around 10K.
So My Problem, if i run and power this from my Pi Zero i can display nearly all numbers apart from 0, 1 or 7, however if I plug a zeroseg in i can display those numbers no problem..
Is this a power issue, or something to do with the fact I am only using 6 digits instead of 8
Cheers
Bod
