lordaker
Re: Dual Monitors
Wed Jan 10, 2018 1:56 pm
This is my xorg.conf
Section "Device"
# RPI HDMI Monitor, framebuffer 0
	Identifier "rpi"
	Driver "fbdev"
	Option "fbdev" "/dev/fb1"
	Option "ShadowFB" "off"
EndSection
Section "Device"
# USB DisplayLink Adapter Video, framebuffer 1
	Identifier "uga"
	Driver "fbdev"
	Option "fbdev" "/dev/fb0"
EndSection
Section "Monitor"
	Identifier "Philips"
EndSection
Section "Monitor"
EndSection
Section "Screen"
	Identifier "primary"
	Device "rpi"
	Monitor "Philips"
EndSection
Section "Screen"
Identifier "secondary"
Device "uga"
Monitor "Philips"
EndSection
Section "ServerLayout"
Identifier "default"
Screen 0 "primary" 0 0
Screen 1 "secondary" LeftOf "primary"
EndSection
Somebody can help me ?
Justin Buist
Re: Dual Monitors
Thu Jan 18, 2018 10:48 pm
I'm working on something very close to your setup lordaker. Here's my xorg.conf file:
Section "Device"
        Identifier "onboard"
        Driver "fbturbo"
EndSection
Section "Device"
        Identifier "displaylink"
        Driver "fbturbo"
EndSection
Section "Monitor"
        Identifier "pihdmi"
EndSection
Section "Monitor"
        Identifier "customer"
EndSection
Section "Screen"
        Identifier "screen0"
        Device "onboard"
        Monitor "pihdmi"
        DefaultDepth 16
        SubSection "Display"
                Depth 16
                Modes "1024x728"
        EndSubSection
EndSection
Section "Screen"
        Identifier "screen1"
        Device "displaylink"
        Monitor "customer"
        DefaultDepth 16
                Depth 16
                Modes "1024x768_60.0"
        EndSubSection
EndSection
        Identifier "Default"
        Screen 0 "screen0" 0 0
        Screen 1 "screen1" RightOf "screen0"
        Option  "Xinerama" "true"
EndSection
It's kind of working but there's some quirks. Notice the Mode line in the first monitor -- 1024x728 not 1024x768. While the monitor only works in 1024x768 mode accidentally trying 1024x728 helped. When X fires up my second monitor (/dev/fb1) lights right up but at the wrong resolution. It's at 1920x1080. The primary monitor (/dev/fb0, onboard) is totally black. If I hop to a tty (ctrl+alt+f2) and login, set DISPLAY=:0 and then launch 'arander' and hop back to vt7 (alt+f7) NOW my primary screen comes up. There's no arandr program on the screen though and I don't know why.
I suspect I need to tweak refresh rates on the monitor to get the two to function at the same time upon first boot. If I figure it out I'll post the final answer.
The setup I've got is a Pi3 running Raspbian Stretch, xserver-xorg-fbturbo package installed, using a DisplayLinkn 165 USB 2.0 dongle for the second monitor.
lordaker
Re: Dual Monitors
Thu Feb 01, 2018 9:36 am
In the section of your xorg.conf where you put this one:
Section "Screen"
        Monitor "customer"
        DefaultDepth 16
                Depth 16
        EndSubSection
EndSection
If I made same thing with my monitors, I will solve my problem of display ?
My resolution screen for two monitors Philips Brilliance 220sw is 1680x1050. I will try with the configuration of your xorg.conf;
Because I don't use the subsection in xorg.conf @Justin Buist. Let me see that and I'll comeback with the result that I have.
rwolenski
Re: Dual Monitors
Fri Apr 27, 2018 9:32 pm
I have a Doublesight USB monitor that I have hooked up and just set mine up with
################## Device Definitions  #########
######### Dual Monitors ############
Section "Device"
  Identifier "uga"
  Driver "fbdev"
EndSection
Section "Device"
  Identifier "RPi_HDMI"
  Driver "fbdev"
EndSection
################ Monitor Definitions ###########
Section "Monitor"
  Identifier "USBMonitor"
  VendorName "DoubleSight"
  ModelName "DS-70U"
EndSection
Section "Monitor"
  Identifier "HDMI_Monitor"
  VendorName "Standard HDMI"
#  Option "DPMS"
EndSection
############## Screen Definitions #############
Section "Screen"
  Identifier "USBScreen"
  Device "uga"
  Monitor "USBMonitor"
    Modes "800x480"
  EndSubsection
EndSection
Section "Screen"
  Identifier "Main"
  Device "RPi_HDMI"
  Monitor "HDMI_Monitor"
EndSection
################ Actual Layout ################
  Screen 1 "Main" 0 0
  Screen 0 "USBScreen"
EndSection
I have both monitors come up, however only I can only access the USB monitor, can't get to the HDMI monitor. It's there, the desktop and background shows up with no menu bar, but I can't access it. Any ideas?
Who is online
