Thu Feb 02, 2012 11:53 pm
TV really sucked today, so I gave it a first shot…
All you need is A4 sized cardboard and a really sharp knife (cutting cardboard is a PITA). The only holes you'll have to make are for RCA and Audio, everything else is given by the shape. The case is pretty robust and there is no need to glue anything.
The picture shows the inside of the case. The RasPi will be "mounted" on the green part at the front, which will be folded onto the bottom to support the board in the middle and leave some space for the SD card slot on the left side. The right side of the board will be supported by the green ends at the right, once the case is closed.
If anyone is interested in adopting this solution I will make a refined version including measures once I have my first Ras-Pi.
edit: I do not take any responsibility for heat or fire damage
to myself: add opening for power supply and add green at the left as well.
