Mumiekage
5" HDMI Touchscreen
Mon Dec 31, 2012 10:45 am
Hello All,
Firstly, I originally posted this in the "What Periphials?" section of this forum, which I fear was an error. So, here it is:
I have been designing a TFT LCD module that will plug into the HDMI port on the RPi. It also has
touchscreen capabilities using an IC to go from 4-pin touch screen (2-pin X-Y positions) to SPI and another IC to go from SPI to HID USB.
I was wondering a couple of things...
[1]
  1. Would anyone else be interested in owning one of these? As with most things, the cost per unit
    decreases as quantity goes up; so, should I make a Kickstarter project for this? The cost would be
    around 65.00 to 75.00 USD.
[2]
  • What additional features should it have? Forum member AwallinI suggested GPIO control to turn on/off the display; I can also add:
    • - Back-light control
    • - Extension of the GPIO pins
    • - Speakers
    If you think any of these would be useful, or can think of something
    else, let me know.
Just reply with answers or contact me at : [email protected]
P.S. I am planning my wedding to occur in May, so if I don't respond right away... please be patient.
haydenbarton
Re: 5" HDMI Touchscreen
Thu Jan 17, 2013 3:46 am
I for one would be very interested in experimenting with one of these and would love to own one.
recantha2
Thu Jan 17, 2013 8:11 am
I would say do a Kickstarter - it's a good way of getting, essentially, 'pre-orders'.
Michael Horne - @recantha
Raspberry Pi blog - http://www.recantha.co.uk/blog
Cambridge Raspberry Jam
Website: http://camjam.me
Facebook: https://www.facebook.com/cambridgeraspberryjam
Follow the Cambridge Raspberry Jam on Twitter - @cambridgejam
jjackowski
Tue Jan 22, 2013 9:01 pm
I could see putting on of these on or in a wall, especially if it isn't much larger than it needs to be. That makes me wonder if speakers are a good idea unless optional; they may take up a bit much space. Even better if a little water dripping down the screen from wet fingers won't get inside to do any damage.
cali0028
Fri Feb 01, 2013 6:40 pm
I am interested in this if you are still doing the project.
freerpg
Sun Feb 03, 2013 11:30 am
I am interested as long as you have the right programming done
123Pi
Tue Feb 05, 2013 5:06 pm
Dear Mumiekage,
I´m interested in your project also.
Please allow some more questions:
I don´t understand what you mean if you say you are planning a 5" HDMI display.
# Are you manufacturer of this display?
# Did you found such a display and you are programming the driver?
# Do you have technical specifications?
(resolution, colors, voltage)
Is this display without cabinet available?
If you are planning speakers, please make it as option.
I´m interested in the pure display for now.
What is your timetable?
Do you have prototypes actually?
Thank you in advance
jfornango
Contact: Yahoo Messenger
Tue Feb 05, 2013 8:13 pm
Curiosity question: Why go to SPI, then USB? Why not pipe the touchpad X-Y leads into an ADC and run it into the GPIO directly?
Not meaning to criticize. I'm curious if you are aware of a GPIO issue that I haven't forseen? Just trying to expand *my* knowledge of modern technology.
I'm only wearing black until they find something darker.
AndyA
Wed Feb 06, 2013 7:33 pm
jfornango wrote:Curiosity question: Why go to SPI, then USB? Why not pipe the touchpad X-Y leads into an ADC and run it into the GPIO directly?
Using a trouchscreen controller rather than a raw ADC makes sense, there minimal no cost penalty it makes life a lot easier.
However since the linux kernal supports SPI trouch screen controllers and the Pi has an SPI interface the jump from SPI to USB seems a little pointless for the Pi, it adds cost and uses up a USB port in order to make the software side a little simpler (no need to install a kernal module and enable SPI).
The big plus in USB is that it means the display can be used on non-Pi devices.
SunTzu
Sat Feb 09, 2013 7:18 pm
I would buy one, but I'd prefer it if you could use that DSI connecter on the RPI. Speakers are a plus. You should make the frame holding the screen and speakers easy to snap onto the RPI so that is provides a sort of housing. It'd also be nice if you were able to combine all the power systems. Maybe have something like a micro usb port coming off of the power system of the screen and speakers so that you can power the RPI with the same source.
stevenroose
Fri Feb 15, 2013 12:21 pm
I'm looking for a 5" touchscreen for a Pi, so I would be very interested.
Please make sure it's easy to use!
Still considering a Kickstarter?
maggiekean
Thu Feb 21, 2013 10:06 pm
I would be very interested. Please let me know if it's a go! For what it's worth, while I like the idea of a touch screen, what I really need right now is a small but high-resolution monitor for a tiny computer. I'm teaching a class and a bunch of kids want to do this project http://blog.parts-people.com/2012/12/20 ... rpi-to-go/ but want a bigger monitor. I want the high res so we can read text -- VGA minimum, more would be nice.
nemmeh
Tue Feb 26, 2013 4:58 am
I too would be interested in this project.
Kickstarter would be a good idea.
Keep us informed! =)
Thanks,
Nem.
mrpi64
Fri Mar 01, 2013 10:58 am
I would LOVE to buy one. I'm in UK, though. I have been looking for AGES for a 5 inch touchscreen! :D
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
dan3008
Thu Mar 07, 2013 4:39 pm
Any news?
dan3008 wrote:Pays your money, takes your choice
rodrinauta
Tue Feb 18, 2014 3:58 pm
Im interested
But it's been more than a year since last news ?
(speakers would be a good option, also a case for easy panel mounting)
Could anyone help my find a 5" HDMI touchscreen ? (web stores ?)
I need it for my car project ;)
rodrinauta
