limpygnome
40 LEDs using a single pin
Fri Dec 28, 2012 10:52 am
Would it be possible to power 40 LEDs off a single pin using five shift-registers and 220 Ohm resistors between each LED and the shift registers? Would this cause damage in the long-run?
I am currently building a clock that will be online 24/7 (as an alarm clock, display clock and partial room automation); currently the clock will power:
> An 8-channel relay
> An MCP3008 ADC, with a: temperature, light and ultrasonic sensor attached.
...however I am not sure if adding an additional 40 LEDs would be possible or cause damage.
Thanks!
bugsy_malone 666
Re: 40 LEDs using a single pin
Fri Dec 28, 2012 12:52 pm
You might be ok, I have seen shift registers used in a massive display before, I think you would need to look a t a different power supply to power both LEDs and Pi.
When we had a display at work that consisted of an LED matrix (8x5 modules but lots of them to display txt) I stripped the units down and they had fairly sizeable 5v PSU's on them but it worked out hundreds of LEDs they were powering plus a module that held the data (these were being scrapped so I kept the bits.)
theres some info here: http://arduino.cc/en/Tutorial/ShiftOut about connecting shift registers to drive sets of LEDs. I have seen 512 LEDs driven by shift registers and an Arduino before, but theres no way the arduino has the oompth to power that many on its own.
So basically I think you'd be ok with your plans, but you would have to design it in such a way as to have a PSU and a common 5v rail to power everything off of.
I'm not 100% but hopefully that is a pointer in the right direction. :)
mahjongg
Fri Dec 28, 2012 1:03 pm
Single pin no, you need several pins, at least a clock pin and a data pin, but quite probably you will need a "parallel load" pin too.
limpygnome
Fri Dec 28, 2012 1:10 pm
Since I'll have a power supply of 240v / with a 13 amp fuse going to my relay, is there a way I can use that power for my Pi and the LEDs? How would I connect that to both of them safely? I assume I would only need to change the voltage? How would you recommend I also do that? :D
Also the shift registers do work, my only concern is the power supply - especially over a long period of time :D.
Thanks!
mahjongg
Fri Dec 28, 2012 1:17 pm
I wouldn't recommend using the same supply that you also use for relay(s), relays can cause some nasty spikes on the power, still if you insist, you can use a cigar plug converter with an USB output.
limpygnome
Fri Dec 28, 2012 2:11 pm
I was thinking of making my own power supply:
...with 10v electrolytic capacitors and the following voltage regulator:
http://www.maplin.co.uk/1a-positive-fix ... tors-46475
Would this circuit work? I would of-course, if this did work, replace the LED with the Raspberry Pi (I could modify a USB adapter) and build a similar second circuit for the LED matrix.
Thanks again! :D
BirchJD
Fri Dec 28, 2012 2:46 pm
Do not connect a 7805 regulator to mains. You would need a transformer to bring the voltage down to something like 9V and a bridge rectifier. The circuit is not correct at all and unsafe if this is the regulator you are planning to use.
http://www.newsdownload.co.uk/
techpaul
Fri Dec 28, 2012 2:51 pm
limpygnome wrote:I was thinking of making my own power supply:
Simple answer DONT Your diagram is so wrong and DANGEROUS
Thanks again! :D
At this stage BUY a SAFE power supply, unless you have a good idea of how to wire mains and build power supplies, dont for your own safety.
You need to do a lot of research on power supplies, yes people can build their own, but you need some knowledge or a defined kit of parts and safe cirucit first
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
limpygnome
Fri Dec 28, 2012 2:59 pm
Thanks!
ReadiesCards
ultrasonics in the bedroom
Sat Dec 29, 2012 7:11 am
Would love to know why you need an ultrasonic sensor in the bedroom?
Are you
- detecting burglars in the room and going to flash a big led matrix saying 'get out'?
- listening for bats and using a relay to fire a fishing net to catch them?
- seeing if your pets come in wanting feeding and opening a pet food supply automatically?
Most interested please do tell
Paul
davorin
Sun Dec 30, 2012 12:48 pm
By "single pin" I assume to transfer the data to the LEDs.
To my knowledge there is no shift register just working with one pin.
But there was a solution once used by Apple called desktop bus.
Older MACs had small microcontrollers from GE (later they went to Microchip)
which used just one data/clock line. The data was encoded as a sort of pulse width modulation with a fixed period time.
Just remembering this as I programmed Microchip controllers to be used as a desktop bus periphal.
So find a big enough PIC with enough LED ports ;-)
Ravenous
Re: ultrasonics in the bedroom
Mon Dec 31, 2012 11:30 am
ReadiesCards wrote:Would love to know why you need an ultrasonic sensor in the bedroom?
Are you
Paul
My guess is he's building a nightlight, so the LEDs automatically come on when you tumble out of bed in the dark winter mornings. (I did one myself years ago, not pi-based but just simple electronics and an IR proximity sensor.)
Lonewolff
Mon Jan 07, 2013 11:12 am
limpygnome wrote:Image
BANG! :lol:
Loving my peice of the Pi
