JimDod
Tall Case?
Wed Dec 26, 2012 4:32 am
Is anyone making a tall case that could hold a XBee on a GPIO adapter card, wold like to have about 45mm above the RPI PCB.
JimDod
Re: Tall Case?
Tue Jan 15, 2013 4:13 am
Guess not.
malakai
Re: Tall Case?
Tue Jan 15, 2013 4:47 am
As of now I don't know of any over tall cases. I use https://www.adafruit.com/products/859 and just leave the top piece out when I use a device that makes it to tall. The only other option would be a Lego case or modify the files for the Adafruit type to have taller sides would need a cutter though. I know the schematics for that case are out there somewhere. Also Avis Tech (they post on this board) had a successful Kickstarter and are doing some sort of stacking option they haven't finalized design as far as I have heard. http://www.kickstarter.com/projects/623 ... s?ref=live
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
AVIESTech
Re: Tall Case?
Tue Jan 15, 2013 10:23 pm
malakai wrote:As of now I don't know of any over tall cases. I use https://www.adafruit.com/products/859 and just leave the top piece out when I use a device that makes it to tall. The only other option would be a Lego case or modify the files for the Adafruit type to have taller sides would need a cutter though. I know the schematics for that case are out there somewhere. Also Avis Tech (they post on this board) had a successful Kickstarter and are doing some sort of stacking option they haven't finalized design as far as I have heard. http://www.kickstarter.com/projects/623 ... s?ref=live
Thanks again malakai!
Jim-
We have a few different options for add on boards and they should be ready for testing in 3-4 weeks. I'll let you know about xbee compatibility once we get prototypes.
AVIES
JimDod
Re: Tall Case?
Wed Jan 16, 2013 12:15 am
My current solution is a simple ABS project box, It works ok, but mounting the RPI is a pain.
AVIESTech
Re: Tall Case?
Thu Jan 17, 2013 4:38 pm
JimDod wrote:My current solution is a simple ABS project box, It works ok, but mounting the RPI is a pain.
I see...what are you using to mount it now?
JimDod
Re: Tall Case?
Thu Jan 17, 2013 5:00 pm
I use some small nylon Hex Standoffs like http://amzn.com/B00137PXNS along the esge of the board in places where the nuts would not damage anything.
