sgsax
Re: Xibo player (work) on raspberrypi
Fri Apr 15, 2016 4:22 pm
Unfortunately, the python client is very old, unmaintained, and not very reliable. I'm guessing there's some timeout going on internally due to it taking a long time to download images, especially if you change your layouts frequently. I've been finding that I never get my layouts refreshed while running on my RPi 1. I always have to reboot to get any updates.
Seth
Uboot
Sat Apr 16, 2016 11:16 am
maxiarg wrote:Hi! I'm from Argentina, so sorry for my English.
I installed Xibo Client 1.6.0-rc2 (from Balmond image) on my Raspberry Pi 2 B. It's working well, but when I enter the command to starts the client ("./run.sh"), and after the Xibo splashscreen appears, the client doesn't start until i press "i" in the keyboard (at this moment appears the screen of the Xibo Client, with information like ip address, etc), and then press "l". When I press "l", the client starts the communication with the server and downloads the content to display. But if i don't press this buttons, the client waits for my input. It not always happens, but sometimes yes.
Is this normal? How can i tell the client to start automatically when i run "./run.sh"?
Thanks!!
Regards,
Maxi
test with this image: http://bit.ly/1T3wvYl for Rasp Pi 2 Xibo Client and Server - unpack with RAR5
:mrgreen: :mrgreen:
bigfootsam62
Sat Apr 23, 2016 2:26 pm
Hello All,
I'm new with Raspberry and I have got my a Pi 3 Model B
I want to Setup a Xibo-Player and spent almost 3 days with several coding, forum searches and reinstallations...
On my Pi 3 but chance. Any help if you please.
sgsax
Sat Apr 23, 2016 5:02 pm
I tried making this work for two weeks. I was able to get a bootable image with a hybrid of a jessie kernel and wheezy system files. I could get the xibo player to start, but it would only display my first image and then black screen for the rest. Unfortunately the xibo linux client is abandoned with no update or replacement in sight. It does not work on modern distro releases due to its use of old and deprecated AV and browser libraries. I have since given up on xibo and rolled my own very simple digital signage solution that fits all of my needs and runs very nicely on my RPi3 with chromium browser from the 3rd party repos.
Seth
Uboot
Mon Apr 25, 2016 2:08 pm
bigfootsam62 wrote:Hello All,
Xibo images only for Raspberry Pi 1 and Raspberry Pi 2
Images for Raspberry Pi 3 NOT available
:mrgreen: :mrgreen:
CrazyBoyS
Thu May 05, 2016 5:47 pm
I am running this and finally found the site.cfg file.
After the reboot it will not find my hosted server on my network with my Xibo setup. My server never sees the Raspberry.
# Xibo Site Configuration File
# Copy this to site.cfg in the same folder as XiboClient.py
[Main]
# Change to the URL of your Xibo server
xmdsUrl=http://tickets/xibo <-- my XIBO server on my network which works with the Windows client app.
# Change to a random string. Used to generate your client key.
# Must be unique for all your clients
xmdsClientID=raspberry1 <-- my random name to tell me what this one is
# The server key for your Xibo server
xmdsKey=KDPE8o <-- my Key
# How frequently to poll the Xibo server for updates (in seconds)
xmdsUpdateInterval=120
# Require a valid connection to the server for the client to start
# If the server is unavailable or the client is unlicensed, sit
# at the splash screen.
requireXmds=true <-- set to this to make sure it shows its connecting to my server and not the internal server.
# Width of the Xibo Client window to use (or screen width if fullscreen)
width=1920
# Height of the Xibo Client window to use (or screen width if fullscreen)
height=1024
# Run fullscreen? Can be true or false. Case sensitive.
fullscreen=false
[Logging]
logWriter=XiboLogXmds
logLevel=0
[Stats]
collect=false
queueSize=10
Any ideas?
arizsn
Fri May 13, 2016 4:19 am
Hi guys!
I'm using raspberry pi 2 and using image from uboot http://bit.ly/1T3wvYl
I tried to login xibo web interface with username: xibo_admin and password: xibo
viewtopic.php?f=41&t=25929&start=575
Unfortunately, that didnt' work and it said "Sorry the form has expired. Please refresh"
What can i do to solve this problem?
Thank you.
Uboot
Thu May 19, 2016 8:29 am
CrazyBoyS wrote:I am running this and finally found the site.cfg file.
[Main]
width=1920
height=1024
fullscreen=false
[Logging]
logLevel=0
[Stats]
collect=false
queueSize=10
Any ideas?
hello,
xmdsUrl:
internal network or external? test with IP adress?
:mrgreen: :mrgreen:
Uboot
Thu May 19, 2016 8:38 am
arizsn wrote:Hi guys!
Thank you.
https://answers.launchpad.net/xibo/+question/73115 solves your problem?
:mrgreen: :mrgreen:
ankitgoenka
Wed Jun 15, 2016 5:16 pm
I went through too much information could someone please post ready to use Raspberry Pi xibo iver image and oblige
jpinzon408
Tue Aug 23, 2016 4:36 pm
Hi, someone has the image of Xibo to RPi2 and RPi3 already running.
michalis88
Tue Sep 20, 2016 9:53 am
Hello, I successfully running the Xibo client image to my RPi3.
How to make it run on RPi3:
Make an sd card with rasbian os (eg wheezy)
Backup the boot partition (copy it e.g. to your desktop)
Make an sd card with Xibo 1.6 RPi 2 image
Delete the boot partition and copy/paste inside it the files from 2nd step
Put the sd card to RPi3 and power it on
Connect RPi with internet (ethernet connection)
Download PuTTY (the SSH and Telnet client itself) and make an SSH connection with your RPi. (you need to find the IP of it, see here: https://www.raspberrypi.org/documentati ... address.md
Username pi Password raspberry
Execute:
* sudo apt-get update
* sudo apt-get upgrade
* sudo apt-get dist-upgrade
* sudo apt-get install ttf-mscorefonts-installer
* sudo apt-get clean
Restart
Correct time zone: sudo raspi-config
Done!
michalis88
Tue Sep 20, 2016 9:56 am
I have problem with scrolling text... Anyone who can help with this? I think that it's problem of libavg (or chromium).
marcelonm
Fri Oct 21, 2016 7:35 pm
michalis88 wrote:Hello, I successfully running the Xibo client image to my RPi3.
Execute:
Restart
Done!
Hello, michalis88, good afternoon.
I would like your help on installing Xibo in raspberry PI3. I saw you posted on the forum that could. I'm following in his footsteps but could not succeed.
It would bother to record a video showing how to get? Please!
I thank you and big hug!
michalis88
Thu Jan 05, 2017 9:50 am
Hi! Try this:
-Burn the "Xibo for Raspberry Pi 2" image file to sd card
-Open the boot partition in your computer, delete everything, and copy-paste the contents files from zip file that you will find below
-Put the sd card to your RPi3 and power it up
Then follow the steps from my previous post.
Link for boot files: http://www.megaupload.us/2S2/boot.zip
dogtown163
Fri Jan 13, 2017 10:37 am
michalis88 wrote:Hi! Try this:
Hy man, thank for you manual, but your boot.zip file is invalid can you upload the new boot.zip?
thanks
emeric.mlcrd
Mon Jan 16, 2017 9:57 am
thanks
Hello, I am in the same case, impossible to run the image on the RPI3 ...
Can you re-upload the boot partition or an image for the RPI3?
Thank you very much for your help !
marcelonm
Tue Jan 24, 2017 4:31 pm
Thank you, Michalis88! I'll be doing the test and I'll show you the result!
emeric.mlcrd
Wed Jan 25, 2017 11:03 am
Perfect, I test soon !
emeric.mlcrd
Fri Jan 27, 2017 10:10 am
It works ! I upload the full image soon !
Thank you !
dutchtoro
Fri Feb 03, 2017 11:36 am
Any news about the full image?
marcelonm
Tue Feb 14, 2017 11:51 pm
michalis88 wrote:Directly from my sd card:
http://wikisend.com/download/859824/boot.RPI3.zip
Michalis88,
I did as you said.
I used win32diskImager and recorded the Xibo16-RPI2 image in SD.
As soon as it finished, I opened the SD and deleted all the files and pasted the files you sent (boot.RPI3).
When I put the SD in the PI3, it starts, locks the keyboard and mouse and begins to pass random images.
It gives me no chance to change anything.
What am I doing wrong?
Can you help me?
Thank you very much.
marcelonm
Mon Feb 20, 2017 10:13 pm
Thank you, emeric.mlcrd!
I downloaded the image that I sent and installed in PI3 and it was able to start.
But I can not get it to sync with the server!
What do I need to do?
Would you put here a step by step summary?
Please!
Thank you
