geoffr
picfan - A PWM cooling fan controller written in C
Wed Sep 11, 2019 7:06 am
With the Pi 4b+ being such "hot property" - quite literally speaking, I found the need to run a cooling fan. Given that my Pi4 still spends a lot of time doing very little, I don't want the fan running full tilt all the time. That led me to start working on controlling the fan using PWM.
The result is the beginnings of a daemon which provides PWM control of a fan which can be controlled via hardware PWM on GPIO 18 (pin 12).
I have now uploaded the code to GitHub: https://github.com/gmrza/picfan.
Please keep in mind that this is very much alpha code. If it blows up your Pi, don't blame me!
You can set the target temperature and a few other things either via a config file in /etc (picfan.conf) or using command line options.
Documentation is pretty much non-existent at the moment.
PeterO
Re: picfan - A PWM cooling fan controller written in C
Wed Sep 11, 2019 8:14 am
A couple of questions....
What type of fans have you tried this with ?
Did you use any external circuit to control the fan ?
I'm currently using a fan-shim and controlling it with the kernel device configured with
"dtoverlay=gpio-fan,gpiopin=18,temp=65000"
ISTR the Pimoroni guys saying their fan doesn't work with PWM, but that may be a misinterpretation of "we don't use PWM" so I might just give it a try 8-)
PeterO
geoffr
Wed Sep 11, 2019 8:46 am
Hi Peter,
at the moment I'm using a cheap 30mm "Pifan" it is doing the job nicely of keeping a Pi4 cool. One reason why I didn't use the gpio-fan overlay is because it didn't seem to handle GPIO.
I probably can still improve the control, as it is challenging to respond quickly enough, but not overreact.
I'm using a separate circuit to drive the fan - it uses a NPN transistor together with a small capacitor to help smooth the output plus a flywheel diode. The reason I used a BJT rather than a MOSFET is because it is easier to find a BJT that can handle the current you might run with a fan - the smaller MOSFETs are a bit on the borderline in terms of the current they can handle.
I was debating looking at getting a 4-pin fan that already handles PWM, but gave up looking after I decided that it wouldn't be worth the effort to find one. I am still debating whether it wouldn't be worth shelling out on a Noctua fan for a production workload.
I am finding that most of the time with low CPU load, the fan is being run on about a 4% to 6% PWM duty cycle to maintain a temperature of 50 degrees. With this approach, using PWM, I manage to keep the fan fairly quiet.
PeterO
Wed Sep 11, 2019 9:34 am
Hi Peter,
Thanks for the answers/info Geoff.
The fan overlay was revised a few weeks ago as it was buggy but it works as advertised now :-) The fan-shim is quite quiet, it's about the same level as the USB hard disk I use so I hardly even notice it above the domestic ambient noise level.
OK about the buffer transistor,diode and capacitor. Is the capacitor across the fan and how big is it ?
PeterO
geoffr
Wed Sep 11, 2019 9:47 am
PeterO
Maybe my cheap fan is noisy ;-) Although I would find some hard disks a bit noisy.
I'm using a 100nF ceramic cap across the fan. The flywheel diode is probably a bit overspecced, as I happened to have a few 1N4001s knocking about.
