jdonald
Re: Introducing Pi386
Sun Sep 01, 2019 2:36 pm
dqs105 wrote:
Tue Aug 27, 2019 4:09 am
Buster on Pi 4B, which already have a 3G/1G kernel.
Awesome, thanks for the heads-up. This makes the whole setup easier and fixes the biggest pain point with "Pi386".
When I tried to execute wine, it shows "Bus error".
My Wine system got into this mode yesterday, then everything was fixed just by rebooting.
I recall seeing something like this on mikerr's image a year ago. Would be curious to rootcause, but it seems difficult to debug unless someone can tell me how to run the armhf strace or gdb from inside the i386 chroot!
I'm also running an i386 Stretch chroot on Raspbian Buster, because trying to make an i386 Buster chroot resulted in segfaults on --second-stage. Furthermore PlayOnLinux doesn't appear to have a Wine build newer than 3.20. What configuration are you using?
dqs105
Mon Sep 02, 2019 6:32 am
Rebooting doesn't work for me. Even reinstalling the whole system doesn't fix it...
From the log, It is ldconfig which causes the problem. Running ldconfig in i386 Buster chroot directly also results in segfault.
I just followed the directions on https://wiki.winehq.org/Debian , which is the official site of wine.
BTW, has anyone tried to build qemu 4.1.0 on Pi? Maybe upgrading qemu will solve this.
dqs105
Mon Sep 02, 2019 1:30 pm
Here, I have something interesting.
I used the same way I did setting up an i386 environment to set up an amd64 debian stretch environment.
Surprisingly, it worked!
Both 32-bit and 64-bit codes can be run with qemu-x86_64-static and qemu-i386-static.
Then, I installed wine.
Here comes the confusing part:
wine64 works(wine64-preloader renamed, wordpad comes with wine works), but wine(the 32-bit one) doesn't.(still, "Bus error")
However, when I tried to launch a 32-bit windows program(copied from my laptop), the program launched!!!
But, after a few seconds, the program died.
That's strange.
Here's something else I found:
1. /sbin/ldconfig is statically linked, while most other programs are dynamically linked to libc.
2. I made an amd64 buster chroot on my laptop, then switched to my Pi. The chroot works, except /sbin/ldconfig.
3. QEMU itself lacks much support.
4. Running programs in chroot environment has some limitations.
jdonald
Mon Sep 02, 2019 6:33 pm
Hey thanks for digging into all of that. Hopefully your info will help someone find a fix for the Buster chroot ldconfig problem.
Ahh cool. I had been using the PlayOnLinux binaries mainly as instructed by novaspirit's tutorial. Using the standard ppa as you've pointed out provides version 4.15 from winehq-devel.
Oh I neglected to mention that I compiled qemu static from source and am using 4.0.95 (v4.1.0-rc5-dirty). I wasn't sure that mattered but apparently it does. I just uploaded my binaries here edit: something regressed and segfaults by commit 23919ddfd5 so use this instead: f28ed74fd1. I had to install both qemu-user-static from apt and overwrite with these files, because I think the repo installation does some necessary setup with binfmt-support.
Cross-compiled in an x86_64 laptop's Buster container so it takes a couple minutes rather than hours. Procedure was roughly as follows:
git clone git://git.qemu-project.org/qemu.git
cd qemu
sudo dpkg --add-architecture armhf
sudo apt-get update
sudo apt-get install -y g++-arm-linux-gnueabihf flex bison libglib2.0-dev:armhf # and possibly other lib*-dev:armhf deps
./configure --cross-prefix=arm-linux-gnueabihf- --prefix=$(pwd)/usr --static --target-list="i386-linux-user x86_64-linux-user " --enable-linux-user --disable-system
make && make install
cd usr/bin
for f in *; do mv $f $f-static; done
cd -
I included the x86_64 part for future use, but haven't tested it.
shadowownz
Fri Sep 27, 2019 3:25 pm
cd qemu
sudo apt-get update
cd usr/bin
cd -
libpixman-1-dev is needed as well. How long did it take to make && make install on a pi 4?
jdonald
Sat Sep 28, 2019 2:28 am
It took about 3 minutes to cross-compile. I didn't attempt to build natively, because RET80 said that would take about 4 hours.
Botspot
Mon Dec 02, 2019 7:53 pm
Any Pi 4 support?
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
brunetton
Mon Dec 16, 2019 12:04 am
I'm very interested in Pi386.
What do you think about creating a git repo on GItlab / Github ?
brunetton
Wed Dec 18, 2019 2:14 am
Thanks for this very inspiring project.
I installed it today, then installed wine inside the container, then tried to run it and got immediately the "famous" `Bus error` :s
I read here that some of us solved it by simply rebooting. I tried but since the reboot, impossible to open container:
root@raspberrypi:~# systemd-nspawn -D /var/pi386
Spawning container pi386 on /var/pi386.
Press ^] three times within 1s to kill container.
execv(/bin/bash, /bin/sh) failed: No such file or directory
Container pi386 failed with error code 1.
root@raspberrypi:~# ll /var/pi386/bin/bash
-rwxr-xr-x 1 root root 1.3M May 15  2017 /var/pi386/bin/bash
root@raspberrypi:~# ll /var/pi386/bin/sh
lrwxrwxrwx 1 root root 4 Nov  9  2018 /var/pi386/bin/sh -> dash
Raspberry Pi3+ / raspbian Buster
Do you have any idea ?
Thanks !
jdonald
Thu Dec 19, 2019 4:57 pm
Sorry to hear that. Yes Bus Error is very frustrating and unclear to debug... you can't simply run strace on something that's running in qemu.
The tests I did above were on a Pi 4 (and thus no guarantees for your Pi 3B+), but I still had to recompile the qemu-user binaries as linked above. Were you using qemu-user binaries from Raspbian's repository, my link above, or somewhere else? What version is it at now?
Pfann
Sun Dec 29, 2019 5:06 am
Hello. Im not that pro with linux and raspberry. But all what i want i can manage (samba server, nextcloud and so on xd:)
My question is.
Is this easy to install for a newbie?
Is it working with my. Pi 4?
And is this like exagear? (to host a teamspeak 3?)
And can i install it on a existing system?
Sorry for my bad english :/
Skaizek
Sat Jan 04, 2020 1:22 pm
So I've compiled Qemu 4.2.50 on my PI4 Buster image and "Bus Error" is gone but when I want to run pi386, or x86 app inside my own x86 Chroot i get "Segmentation Fault" every time
qemu: uncaught target signal 11 (Segmentation fault) - core dumped
And info from running TS3
2020-01-04 13:18:55.177725|INFO    |ServerLibPriv |   |TeamSpeak 3 Server 3.10.2 (2019-11-20 08:39:31)
2020-01-04 13:18:55.201411|INFO    |ServerLibPriv |   |SystemInformation: Linux 4.19.75v64 #1 SMP PREEMPT Sat Oct 5 03:06:01 CEST 2019 i686 Binary: 32bit
2020-01-04 13:18:55.203632|WARNING |ServerLibPriv |   |The system locale is set to "C" this can cause unexpected behavior. We advice you to repair your locale!
2020-01-04 13:18:55.264310|INFO    |DatabaseQuery |   |dbPlugin name:    SQLite3 plugin, Version 3, (c)TeamSpeak Systems GmbH
2020-01-04 13:18:55.266019|INFO    |DatabaseQuery |   |dbPlugin version: 3.11.1
2020-01-04 13:18:55.327033|INFO    |DatabaseQuery |   |checking database integrity (may take a while)
Segmentation fault
Does anyone know how to fix segmentation fault?
I can send Qemu.4.2.50.deb package if you need it too
jdonald
Mon Jan 06, 2020 2:59 pm
I tried the v4.1.0-rc5 build I linked above and it gets further when I ran TS3 minimal. The server runs without crashing, and occasionally it saw traffic when I attempted a client connection (observed via the syscall printouts), although no connection was successful from the client's perspective.
That's not to say the v4.1 QEMU build is really functional. Combined with Wine, every so often the system gets into a state of always Bus Error, then this goes away again upon rebooting. Furthermore I'm still using a Stretch chroot (on a Buster system) because as far as I've heard Buster i386 chroot + qemu-i386 still doesn't spawn.
Have you tried qemu-x86_64-static with TS3 x64? dqs105 reported that x86_64 might be more stable at least for the Raspbian default (v4.0?) QEMU.
Skaizek
Wed Jan 08, 2020 5:46 pm
No, I haven't tried qemu-x86_64-static with TS3 x64 but i can give it a look.
Also I've noticed that version of Qemu I get from apt install is 3.1. I've compiled whole Qemu 4.2 from git, made .deb package of it using checkinstall (For future use), installed it and noticed very interesting thing. Pi386 said that it still requires qemu-user-static so it downloaded 3.1 version from apt.
As a very first post said
qemu-user-static, which allows you to 'chroot' into a filesystem from a different architecture
I think my problem lies in qemu-user-static which is in older version than my compiled Qemu
Or maybe my whole problem lies in Berryboot which I'm using to switch between OS-es quickly, idk, but I will try these 3 things and see what I can get :D
bartislartfast
Mon Jan 13, 2020 10:00 pm
Hi, I am totally new to the pi and linux the environment, so I have no experience of what I am trying to do.
What I want to do is run a TS3 server 24/7 on a Pi4 4G, later I would like to add a cloud/data/media server that I can access from my laptop & mobile.
For now though setting up a TS3 server is my goal, can it be done with Pi386 and if so could someone give me the 'Dummies' guide to set it up?
barti :mrgreen:
ChasTech
Mon Jan 20, 2020 6:26 am
I'm the developer of the project but I switched accounts and my old one is now locked by request. Not sure whether I'm going to continue this project, but if I do it'll probably be built for my Debian 64-bit images since I dont really use Raspbian anymore now that I've got a 4GB Pi 4 (which is ARM64), it would be wasting its capabilities not to have a 64-bit OS to go with it. Maybe even PiA64 could be a thing since my Debian images are ARM64 and theoretically capable of running an AMD64 chroot with qemu-user-static. Who knows?
If apples give you apple pie, bananas give you banana pie, pears give you pear pie, and cherries give you cherry pie, then what do raspberries give you?
A Raspberry Pi :lol:
Jeebus
Mon Jan 27, 2020 3:15 am
I was just wondering if this would work just to play game files, without having to install windows entirely?
I just want to play a single game, maybe a couple along with all the other emulated games.
Thanks.
Methanoid
Mon Mar 23, 2020 3:23 pm
Is there a release link to a IMG of this? Or do we have to build ourselves? I'd like to try this....
SC13NC3F1CT10N
Wed Jun 10, 2020 10:22 pm
Does pi386 come with xorg and systemd-container? :?:
If you turn on Javascript, the text will change.
SC13NC3F1CT10N
Thu Jun 11, 2020 12:29 pm
Figured it out myself, it does not. So I installed them. But when I try to launch Dillo Browser after installing it I get this:
No protocol specified
Can't open display: :0.0
Can anybody help?
rickticktock
Fri Jun 12, 2020 10:17 pm
I say chaps,
In Ubuntu, a flavour of Linux just like Debian is, WINE is a standard bit of software. Some programs are OK with it, some not. One which works very well is LT-Spice which is only available as a Windows download, but runs under WINE just as quickly, if not more so.
TTFN
berba
Sat Nov 14, 2020 6:34 am
Hi all,
If any of you can successfully install Metatrader in pi386, appreciate your confirmation please.
I really want to learn on Metatrader in raspberry pi.
Appreciate your input.
Thanks a lot.
Sat Nov 14, 2020 4:58 pm
I say chaps,
In Ubuntu, a flavour of Linux just like Debian is, ...
Ubuntu is a derivative of Debian. Leaching off all the hard work of the Debian community that existed long before Ubuntu.
...WINE is a standard bit of software. Some programs are OK with it, some not. One which works very well is LT-Spice which is only available as a Windows download, but runs under WINE just as quickly, if not more so.
TTFN
Yes, I have been amazed for many years how well LT-Spice works under Wine on Debian. And hence on Ubuntu as well I guess.
However, that is LT-Spice under Wine on Debian on an Intel x86 machine. I suspect it does not run at all nicely on an ARM processor with x86 emulation.
hippy
Sat Nov 14, 2020 5:51 pm
Does that mean Raspbian and now Raspberry Pi OS, which are also derivatives of Debian, are also leaching off all the hard work of the Debian community that existed long before they did ?
Sat Nov 14, 2020 6:10 pm
Yes.
However I believe credit is due where credit is due.
"raspbian" is very up front about being a build of Debian for the Raspberry Pi. It's right there in the name.
Even now Pi OS calls it's current release "Buster" and follows Debian releases.
What annoys me is the way Debian, as the origin, gets buried to the point I read things like "Ubuntu, a flavour of Linux just like Debian" as in the post above.
