FreezeTile
PS/2 on Raspbian?
Thu Oct 25, 2018 3:40 pm
I have an old PS/2 mouse & keyboard, and I'm planning to use them with my Pi. If I buy this adapter - https://www.ebay.co.uk/itm/USB-Male-to- ... 0924574780 - will my mouse & keyboard work on my Pi without me having to know lots of complicated driver things? Thanks! :-)
jahboater
Re: PS/2 on Raspbian?
Thu Oct 25, 2018 4:41 pm
Very likely!
USB keyboards and mice are very cheap in case they don't work.
But my bet is they will work fine.
FreezeTile
Thu Oct 25, 2018 4:46 pm
jahboater wrote: Very likely!
Thanks!
hippy
Thu Oct 25, 2018 4:51 pm
Those look like passive adapters rather than true PS/2 to USB interfaces to me so I would not expect them to work with a Pi.
You need something which more commonly looks like this -
https://images-na.ssl-images-amazon.com ... SX355_.jpg
mahjongg
Thu Oct 25, 2018 5:36 pm
Early in the life of USB keyboards were sold that were really capable operating with both USB and PS/2 interfaces, but came with an PS/2 connectors. If you wanted to use them as USB keyboard you needed a small adapter, containing nothing but wiring but which converted the PS/2 connector to USB.
That means that with such a simply adapter your "PS/2" device MUST also contain USB logic, or it simply won't work.
If you have an "active" adapter that contains the logic for an USB to PS/2 converter, then yes, you should be able to use it with a real PS/2 (only) keyboard.
These days read USB keyboards and mice are so cheap that almost nobody sells such adapters anymore.
Thu Oct 25, 2018 5:52 pm
Something like this should do the trick
https://www.ebay.co.uk/itm/323325042268
FreezeTile
Thu Oct 25, 2018 6:08 pm
How about one of these? https://www.ebay.co.uk/itm/1-PC-black-U ... :rk:7:pf:0
I need an old keyboard & mouse because I'm making an 80's/90's-style Pi setup.
Thu Oct 25, 2018 7:12 pm
That should work too. I have something similar for using ancient keyboards and mices.
FreezeTile
Thu Oct 25, 2018 8:55 pm
rpdom wrote: That should work too. I have something similar for using ancient keyboards and mices.
Ok, thanks! :-)
hippy
Thu Oct 25, 2018 10:22 pm
One thing to watch out for is that some of the adapters don't convey backslash or pipe key presses. That may depend on where the key is placed on the keyboard.
FreezeTile
Fri Oct 26, 2018 11:27 am
I'll keep that in mind.
