ReadiesCards
Secure SD card socket? (vibration proof)
Thu Nov 08, 2012 8:40 pm
Considering installing a RPi in a highly vibrating vehicle.
Any ideas how best can I secure the SD card?
(ideally without gluing it in!)
paultnl
Re: Secure SD card socket? (vibration proof)
Thu Nov 08, 2012 8:50 pm
Simple approach would be an elastic band
I don't like Russian dolls, they are so full of themselves
notarat
Thu Nov 08, 2012 9:49 pm
ReadiesCards wrote:Considering installing a RPi in a highly vibrating vehicle.
+1 on the rubber band idea.
techpaul
Fri Nov 09, 2012 11:16 am
paultnl wrote:Simple approach would be an elastic band
Hmm wrong way round if you have vibration area you need to clamp together connections, and provide shock absorbing mounts for the board. Elastic band will allow movement opposite of what you want, movement means intermittent connections
Suggest you find a way to clamp SD card to socket or have some insulating stiff material hold the SD card down. Not glue SD card down, but something over the SD card socket to hold the SD card down.
Rubber feet glued to board is minimum of shock mount I would do, consider what the engine mounting blocks in a car are bolts through a thick stiff rubber block.
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
