FreezeTile
Connecting a Pi to an 80's monitor?
Thu Sep 27, 2018 1:25 pm
I recently picked up this vintage green-screen computer monitor from c. 1983, and I thought it would be fun to use it with my Pi and other devices.
How would I buy/build a video cable that connects a male composite jack to the DIN(?) socket on the back of the monitor?
Here are the pinouts:
Andyroo
Re: Connecting a Pi to an 80's monitor?
Thu Sep 27, 2018 1:51 pm
First convert to VGA https://thepihut.com/products/raspberry ... -convertor
Then convert VGA to comp. sync http://www.epanorama.net/circuits/vga2rgbs.html
No idea if it will work but I would try command line first :D :lol: :D
B.Goode
Thu Sep 27, 2018 2:08 pm
My, 'try the simplest thing first,' approach would be to connect the composite video output from the 3.5mm jack on the RPi to the Composite In on pin 4 of the monitor.
scotty101
Thu Sep 27, 2018 4:35 pm
That was going to be my response too. I'd connect the ground to the "earth" pin too.
Unusual connector... I thought it might be similar to the commodore 64's DIN connector but apparently not.
FreezeTile
Fri Sep 28, 2018 9:16 am
B.Goode wrote: My, 'try the simplest thing first,' approach would be to connect the composite video output from the 3.5mm jack on the RPi to the Composite In on pin 4 of the monitor.
It worked! I connected pins 3 and 4 to a female composite jack and now it displays composite video! Now all I need is a 3.5mm to RCA adapter.
Here's a picture of my Super Nintendo plugged into the monitor.
Fri Sep 28, 2018 10:16 am
That green brings back a few memories!
scotty101
Fri Sep 28, 2018 10:32 am
memories... and a migraine!
