bobfunduro
Using (multiple) Pi as a main stream computer
Fri Jul 27, 2018 3:09 pm
Hi All.
Following my recent successes "Getting Started" The Bottom Line. Thanks PI ! Sun Jul 22, 2018 1:52 pm
I'm thinking of using a Pi as a main stream computer and I'm bumping into comments that the Pi is insufficient.
Since buying a dedicated Linux machine is not an option, would it be relatively easy to piggy back say 4 Rpi's to spread the cpu load and aid the insufficient RAM issue that appears on the forums?
Any ideas/leads?
Regards
B.Goode
Re: Using (multiple) Pi as a main stream computer
Fri Jul 27, 2018 3:21 pm
Any ideas/leads?
First idea. Ignore the comments. (To the extent that only you can decide whether an RPi is sufficient for your needs or not.)
Second: " would it be relatively easy to piggy back say 4 Rpi's to spread the cpu load and aid the insufficient RAM issue "
A2: No. It is relatively easy to network a number of RPi systems together, and the Raspberry Pi Foundation have documented how to do it. It won't result in a single 'better' computer as you hope, and it does nothing about the "insufficient RAM issue". But have you actually encountered this issue? Is it a real problem for you?
Bottom line is: if you are seeking a general-purpose computer system with more processing power and RAM than the current top-of-the-range RPi3B+ then the Raspberry Pi Foundation does not presently have a product that meets your needs.
topguy
Fri Jul 27, 2018 3:31 pm
I'm thinking of using a Pi as a main stream computer.
Stream what/where/how ?
Fri Jul 27, 2018 4:21 pm
Hi All.
Any ideas/leads?
Regards
Only if the software you intend to run is compiled to work in a Computer Cluster / Distributed Computer / Parallel Computing scenario.
4 RPis does not make a 16 Core CPU or can run software compiled for x86 architecture...
https://www.google.co.uk/search?q=raspb ... clustering
adieu
The Traveler
Fri Jul 27, 2018 7:32 pm
A inexpensive, common and easy route to take is to buy a Chromebook and put Linux on it. Works quite well and you can either dual boot Chrome and Linux, or just install Linux. https://www.lifewire.com/install-linux- ... ok-4125253
The RPi has sufficient power to do a number of things but for myself, I still prefer a more "conventional" solution for long term use.
Cheers.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
