My DIY Pi Case
Posted: Tue Apr 17, 2018 9:23 am
by DinksDad
Hi.
Just wanted to share a short video of the construction of my DIY Pi case I made.
https://photos.app.goo.gl/ObMIkQZPQ2GKoTkK2
Re: My DIY Pi Case
Posted: Tue Apr 17, 2018 4:29 pm
by boyoh
Well is it the same box as your last post, Full marks for your Video Editing
and your neat use of Heat Shrink Sleeving Now lets see some projects
come out of the box
Re: My DIY Pi Case
Posted: Sat Apr 21, 2018 2:36 pm
by DinksDad
Many thanks for your reply.
At the moment I'm in the process of moving my house round, then I will set the Pi up as a permanent desktop, using an old TFT tv, wireless keyboard & mouse.
Then I'll crack on with some sort of project, haven't decided what as yet.
Re: My DIY Pi Case
Posted: Sat Apr 21, 2018 8:21 pm
by lwhistler
- What material are you using?
- How did you cut it?
- How is it bonded together?
Re: My DIY Pi Case
Posted: Sun Apr 22, 2018 8:40 am
by DinksDad
The black material is FOAMEX.
It's basically heated, squeezed polystyrene.
It's quite strong, used for Signage backing.
Easy to cut, 'Stanley' knife does the trick.
I cut small pieces, and just glued the lot together (apart from the bottom which is screwed on, to gain access), with a hot glue gun.
The only downfall with it is, it's not heat resistant, so a hairdryer would warp it.
Comes in loads of colours too.
