volantynys
Re: Smart docking station white cloning and hacking functions
Thu Jan 05, 2012 11:46 am
mount a usb docking station on it were 2 sata drives in vit.
and use Hirens boot cd as OS so that you can clone, hack the SAM file, test harddrive easy copy etc.
what do you think?
Warringer
Thu Jan 05, 2012 4:01 pm
Uhm... What?
Can you repeat that in more words so that it may be understood better?
mikeyp
Fri Jan 06, 2012 7:42 am
I understand, I work with these kind of tools myself. He wants to attach hard drives with USB adaptors, and boot from a Hiren's Boot CD to then perform computer maintenance functions such as data backup, hdd imaging, test hdds, and SAM edit (Windows password reset)
In short, yes and no, the Hiren's boot CD is compiled for to run on i386 Intel compatible processors, so won't run from a R-Pi as it has an ARM processor which can't run the code and I believe can't boot from CD either...
That said, there is no reason that all these tools shouldn't be compiled to run on the ARM processor and boot from the SD card as they are (mostly) all open source.
