starous
Adapter for two SD cards
Mon Oct 15, 2012 9:15 am
Hi everybody,
lots of people, including me, are asking about dual-boot options for SD cards to allow two OS on Raspi.
But, what if we had an option to use an adapter for two SD cards, which will switch between them after each reboot. Something similar to SIM card adapters
Image.
Is there any clever electrical engineer, who could design something similar for us? :-)
I'm just a mechanical engineer. I have only ideas ;-)
chucic
Re: Adapter for two SD cards
Fri Mar 27, 2015 10:35 am
also I'm finding this solution.....
but, we needs is at least 3....
OPENELEC + RetroPie + Raspbian
ame
Fri Mar 27, 2015 10:40 am
I can sell you something that allows you to use a second SD card at the same time, for only $35!
Mortimer
Fri Mar 27, 2015 10:46 am
Maybe...
The purpose of a little toe is to ensure you keep your furniture in the right place.
Mortimer
Fri Mar 27, 2015 10:48 am
Actually scratch that, it won't work, the dual slot thingy is a MS Pro Duo device not SD-card.
dan3008
Fri Mar 27, 2015 8:30 pm
something like this, and splicing in a second socket MIGHT work, but youd need to add a switch on at least the power line... Not impossible, but not easy either...
Potentially risky
dan3008 wrote:Pays your money, takes your choice
