ribeye
Re: Home automation via Zigbee
Sat Dec 31, 2011 12:36 pm
Can anyone suggest a strategy for setting up a Zigbee home automation network on Raspberry?
Presumably you need
- Zigbee USB dongle to plug into the Raspberry
- Software running on the Raspberry to control the network and offer access via internet
- A remote control
- The Zigbee light switches etc
My google research has turned up nothing that seems to fit this form.
Gert van Loo
Sat Dec 31, 2011 12:57 pm
Or connect a zigbee device to the GPIO. e.g. use the SPI port to talk to a zigbee chip.
daveismith
Sat Dec 31, 2011 4:08 pm
If you're going to buy off the shelf ZigBee HA products, you're going to need to understand how the HA automation profile works. In terms of physical setup, I would think that a module communicating by SPI would give a nicer finished package personally.
Robin McB
Sun Jan 15, 2012 1:12 pm
Hello
I am planning to put together a couple of Microchip PIC based boards in order to control outdoor lights, read PIR sensors, door state (open|closed|locked), temperature and mains supply in a shed/greenhouse.I want a PC-based interface for setting up, direct control and possibly (later) logging of readings from other sensors.
The sensors, relay outputs, etc will be on or directly connected to a board based around one of the 16F or 18F PICs. This will communicate with another board at "Indoor" end via ZigBee modules from Microchip. These are relatively easy to use  - assuming you are familiar with micro-controller programming!
I was looking at basing the "Indoor" end around  a PIC32 running a basic web server (connected via ethernet) which could then be accessed from wherever required.  Then I found out about the Raspberry Pi!
It seems that a lightweight LAMP server will be WELL within it's capabilities and there's an SPI port ! It seems that a driver for the SPI is not yet done, but given the usefulness of SPI on a board like Raspberry Pi, I don't think that will be long being done - I would be willing have a go myself, although I'm far more familiar with micro-controllers  than Linux.
There are Zigbee modules from several manufactures appearing and most seem to use SPI to talk to the processor (largely because it's pretty much standard on micro-controllers).
If anyone else who is thinking along these lines is interested in perhaps kicking about ideas for a set of common protocols (I know there are some already out there) that would allow for all the various functions that are controllable - irrespective of underlying comms i.e. effectively between the application 'layer' and the actual communication 'layer', maybe Raspberry Pi forums could be the place to open up this discussion?
Ianw
Sun Jan 15, 2012 2:02 pm
Theres a really good book from O'Reilly called 'building wireless sensor networks', it covers everything you need to know about zigbee/xbee protocols and interfacing micro controllers! plus there are plenty of USB zigbee/xbee USB interfaces out there as well for a quck fix to the Rasberry Pi interface side of things!
http://books.google.co.uk/book.....38;f=false
If you need any help with the Microcontroller / zigbee side of things feel free to PM me, I have created quite a few projects using these (can be expensive though)
BlueClogger
Sun Jan 15, 2012 2:16 pm
Sorry, wrong thread.  Content withdrawn.
alchoper
Sun Mar 25, 2012 2:31 pm
Edit by Abishur: You posted this exact same information linking to a commercial product 4 times in rapid succession.  I'd like to think that since they were on topic in the threads you posted them to that you were just trying to be helpful, but 4 times in such rapid succession as your first 4 posts ever comes off as a little spammy.  If that was just an unfortunate accident, I hope you stick around and keep contributing, but I do ask that you refrain from posting links to commercial products until we get to know you a little better
SHNalchoper
Thu Oct 18, 2012 4:40 am
Sorry Abishur. I got carried away spreading the news. Anyway, the topic has also been picked up in another thread (Home Automation with Simplehomenet.com). Indeed, a great way to set up the RPi as a sophisticated and very inexpensive home automation gateway is described here: http://simplehomenet.com/solutions.asp?page_id=HomAidPi
Happy automating..
Azurl
Tue Jan 23, 2018 9:56 am
I've been looking for examples on this. I have recently gotten a raspbee zigbee module for the raspberry pi which basically does what you described here. but the only information I got with it was to use the manufacturers GUI based software called Deconz. I want to build an embedded system that does not employ a screen or keyboard/mouse input. so I want to write the software myself, but I have yet to find any coding examples on how to use the zigbee chips.
Gert van Loo
Tue Jan 23, 2018 7:40 pm
I used "zigbee Deconz" in google an that led me to this:
https://www.dresden-elektronik.de/funkt ... pc/deconz/
Where they advertise "deCONZ V2_04_99 (Raspbian Linux)" and "deCONZ V2_06_11 (RaspBee Firmware)"
