microlost
Is MAGI mining profitable?
Sun Nov 05, 2017 12:16 am
I am looking into setting up a mining operation on a raspberry pi. I would be using a 3b. I am not trying get rich or anything, I am just interested in cryptocurrencies and want to try mining. Based on my research, the best currency for this would be Coin MAGI. Is this true? Is there a better one for this kind of solo mining operation? Would it cover the cost of its own electricity?
microlost
Re: Is MAGI mining profitable?
Mon Nov 06, 2017 4:15 pm
Also, would a different version of rpi be better for this?
S0litaire
Contact: ICQ Skype Twitter
Tue Nov 07, 2017 3:25 pm
I'm currently mining Magi using 4 zeros and a pi3
At the moment It's NOT profitable by any means, but things can change and it's not adding a huge amount to my electricity bill.
it's a nice hobby.
Quick stats on my 4 zeros :
2 x rpi0w = 0.71 khash/s
2 x rpi0 = 0.69 khash/s
In total they are pulling 5.28v @ 0.99a = 5.17w
so uses a kw/h in 8 days
Pi3 gives me 11 khash/s don't have an energy meter attached to it so not 100% sure of it's usage.
It currently taking me around 8-10 days to make a single magi coin.
each coin is roughly worth the same as I get charged for 1kwh of usage so it's safe to say I'm only getting back, at best, 50% of the costs.
But the coin is slowly rising in price by few pence every week or so (Also might make a jump in price later this month!)
So Coin-Magi is not a "Get rich Quick" scheme! It's more of a slow steady increase over the long term...
Laters
Bill "Solitaire" C
Anáil nathrach, ortha bhas betha, do cheol déanta
microlost
Wed Nov 08, 2017 5:22 am
it's a nice hobby.
thanks, what are your electricity costs per kwh? Also, because of the more powerful? cpu and more ram, would the pi3 have better or worse hash rate/electricity usage?
Wed Nov 08, 2017 8:58 am
Last time I looked at eletricity prices running a RPi3B for 24/365 cost about £4.38.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
S0litaire
Wed Nov 08, 2017 9:47 am
I'm paying £0.16($0.21) per KW/h
Each coin is worth between $0.21 - $0.25.
I'm currently doing tests with the 4 zeros to see how much they make, compared to power used, in 24 hours by themselves, I'll do the same for the pi3 tomorrow. (Only have one usb energy meter).
Laters
Bill "Solitaire" C
microlost
Wed Nov 08, 2017 3:13 pm
thanks, cant wait to see the numbers
microlost
Wed Nov 08, 2017 3:18 pm
also, my electrifity is only 7c /kwh, so that might make the difference between profitable and not
S0litaire
Wed Nov 08, 2017 3:28 pm
quick 'n' dirty calculations :
the Pi3 uses 1kw/h in 10 days @ 11.0khash/s
4 x zero uses 1kw/h in 8 days @ 2..8khash/s
So with the higher hash rate of 11khash/s the pi3 is the more efficient choice.
Will have a better write up at the weekend, with the amount of coin generated per device, that will give a better indication
Laters
Bill "Solitaire" C
hippy
Wed Nov 08, 2017 3:56 pm
My electricity bill states it's 15.74p per kWh, so your usage would cost me £7.13 a year. At a coin every 9 days that would be a cost of 17.58p per coin, $0.23.
Of course that's not including the cost of running the Pi3B. Maybe halfway to breaking even at present as you say.
With microlost's electricity at just 7c (5.3p) per kWh that should turn a profit.
S0litaire
Wed Nov 08, 2017 4:51 pm
looking into building a solar + battery setup for my r-pi...
£60 worth of equipment to make £7 per year... lol
but it *is* free energy...
Laters
Bill "Solitaire" C
Thu Nov 09, 2017 3:03 am
So at £0.16 per KWh that's £5.76 for 360 days. How do you know it's using 1KWh in ten days - have you measured it?
Thu Nov 09, 2017 6:16 am
Presumably so, using the USB energy meter mentioned previously in this thread.. Not that they are always that accurate.
Thu Nov 09, 2017 7:57 am
But that's never going to be accurate as it gives an instantaneous value. You need to track power usage over time to get an average, it's probably a good idea to track CPU busy over the same timebase. Then you can come up with a microwatts value that correlates to CPU busy. From there it's simple maths to get an annual cost versus number of hashes calculated for the blockchain currency you're attempting to mine.
Thu Nov 09, 2017 8:25 pm
Most of them also give a cumulative power usage figure in mAh too.
S0litaire
Thu Nov 09, 2017 8:31 pm
Yup it's a cheap and cheerful usb power meter, it keeps a running total of power used a well as a few other measurements.
Laters
Bill "Solitaire" C
JF002
Sun Nov 19, 2017 6:13 pm
How do you achieve 11 Kash/s?
I've just compiled it, and it runs @ 4.4Khash (4*1.1). Did you use special compile options? Overclocking?
My web site : https://codingfield.com
S0litaire
Sun Nov 19, 2017 6:34 pm
Nothing special other than using the 64bit OS
https://github.com/bamarni/pi64
And this version of the miner:
https://github.com/magi-project/m-cpuminer-v2/releases
Compile it as normal (In the first Makefile change the “-march=native” to “-mcpu=cortex-a53” )
then run as normal.
I'm NOT overclocking it because i've only passive cooling with a heatsink.
It seem a bi of a waste to use extra power for a fan that can cancel out the gains from OC'ing ;)
Also the energy usage is 5.2v @ 0.74A giving 3.8w (+/-0.1w)
Laters
Bill "Solitaire" C
JF002
Sun Nov 19, 2017 6:49 pm
then run as normal.
Wow that's impressive! It seems that the 64bits OS improves the perfs a lot!
brasilianman
Fri Feb 02, 2018 6:21 pm
I'm curious on doing this project as well through CPUMiner. I recently acquired a new ClusterHAT to connect my 4 RaspPi Zero-W's to my Pi 3 as the controller. Is this project that you had performed in a cluster setup or each Pi mining by itself?
BeanSampa
Sat Feb 17, 2018 8:58 pm
Nice post!
Just for curiosity, I created a cluster using an old Switch (16 ports) and 6 (six) Rpi3, and installed Pi64 and CpuMiner-V2 as described in this post (thanks).
http://prntscr.com/ig5qmn
In Suprnova, I have the average of 54 Khs and got 0.44372888 XMG in 7 days. (I started recently)
Sometimes more. http://prntscr.com/ig5rm9
In 30 days, I'll get: 1.9 XMG x 0.514805 (coinmarketcap, now) = USD 0.9781295
(without considering increases of difficulty)
Based on the consumption of this post, my cluster will consume in 30 days: 6 x 3 (1 kwh / every 10 days) = 18 Kwh
(without considering Switch consumption)
In my country the Kwh price is USD 0.19. Total cost = 18 x 0.19 = 3.42
My "profit" in 30 days: 0.9781295 - 3.42 = - 2.4418705
I'll pay to get XMG ( :D :D ) . Where I live? B R A Z I L
As I wrote: Just for Curiosity!
Nigel36
Sat Mar 03, 2018 11:25 am
Hi ,
Just reading through the post people seem to me getting around 11 khash/s using a PI3
I seem to get 1-4!
What am I doing wrong?
I'm using a Raspberry PI 3 Model B Mining Magi on MinerClaim.
Is there something I need to tweek?
What factors effect hashrate?
Any advice would be gratefully received
S0litaire
Sat Mar 03, 2018 4:06 pm
Hi ,
I seem to get 1-4!
You need to use the 64bit version if the OS to get the higher speeds :
https://github.com/bamarni/pi64/releases
Then compile the miner again (or get the 64bit app if avalible) then you should get 11kh/s.
Make sure you have a good heatsink/cooling fan on the board it gets hot!
Laters
Bill "Solitaire" C
alextheminer1990
Tue Mar 13, 2018 4:16 pm
It will be great if you could share with us your 64bit os version and which miner u use?
