Hi there,
I have a little project that I don't know if it could be possible. Let me explain:
I'm using a software called PlayBack Pro. This software is use to play video and sound during shows (conventions). I have 2 MacBook, one is the MAIN and the other one is the BACKUP. This software is controlled by an external keyboard via USB, one controller for each MacBook.
I would like to connect the controller to my raspberry and then connect a "USB A Male-Male" from the Raspberry PI3 Model B to the 2 MacBooks and use the Rasp as a "Repeater/splitter" USB. So then I will be able to control the 2 MacBook with only one key hit: play button.
Do you think it's something achievable ?
I know a box that does it but it cost 250$ and it is for Qlab. https://www.teamsound.nyc/store/go-box-6-rev-2
Thank you in advance
