scrishton
Portable ADS-B low flying aircraft alarm
Sat Apr 01, 2017 8:27 pm
I have a Pi in my loft receiving ADS-B aircraft signals and sending them to the Planefinder website. All works very well. Most of the transmissions have location data, but some aircraft, including military ones, only give their altitude.
I have recently started flying a drone. I am very careful to only fly in uncontrolled airspace and below 400 feet where I should be both legal and safe. Unfortunately some of the low flying planes around my home area fly below their supposed minimum altitude of 500 feet.
It should be fairly simple to build a portable low flying aircraft alarm based on Dump1090 which alerts me if there are any ADS-B signals showing low altitude and good signal reception.
I am reasonably familiar with Python, and with GPIO stuff, but don't know how to read the Dump1090 output into a Python script. Any suggestions would be most welcome.
Killer_Hacker
Re: Portable ADS-B low flying aircraft alarm
Tue Sep 08, 2020 5:26 am
I also searching for this kind of ' Low Altitude Flight Alerts ' using my Raspberry pi with Dump 1090 !
Please ...
any suggestions ?
:roll: :?
nliviu
Tue Sep 08, 2020 12:08 pm
The easiest way would be to connect to port 30003 from dump1090 and parse the data.
Example output:
MSG,6,1,1,424776,1,2020/09/08,15:03:22.428,2020/09/08,15:03:22.428,,,,,,,,4701,0,0,0,
MSG,5,1,1,424776,1,2020/09/08,15:03:22.428,2020/09/08,15:03:22.428,,43000,,,,,,,0,,0,
MSG,5,1,1,424776,1,2020/09/08,15:03:22.428,2020/09/08,15:03:22.428,,43000,438,301,,,,,0,,0,
MSG,4,1,1,424776,1,2020/09/08,15:03:22.428,2020/09/08,15:03:22.428,,,439,301,,,0,,,,,0
MSG,3,1,1,424776,1,2020/09/08,15:03:23.465,2020/09/08,15:03:23.465,,43000,,,44.11766,26.85295,,,0,,0,0
MSG,5,1,1,424776,1,2020/09/08,15:03:23.465,2020/09/08,15:03:23.465,,43000,,,,,,,0,,0,
MSG,4,1,1,424776,1,2020/09/08,15:03:23.465,2020/09/08,15:03:23.465,,,439,301,,,0,,,,,0
MSG,5,1,1,424776,1,2020/09/08,15:03:24.504,2020/09/08,15:03:24.504,,43000,,,,,,,0,,0,
MSG,6,1,1,424776,1,2020/09/08,15:03:24.504,2020/09/08,15:03:24.504,,,438,301,,,,4701,0,0,0,
MSG,5,1,1,424776,1,2020/09/08,15:03:24.504,2020/09/08,15:03:24.504,VPCCN   ,43000,,,,,,,0,,0,
The format of the data is described here
pidd
Tue Sep 08, 2020 1:14 pm
Report them to ATC, they usually fob you off on the first couple of reports (sometimes outright denial along with maps that disagree with what you know is fact - one I was was given showed the aircraft didn't go directly over my house - I saw it!) but if you show a pattern they eventually start to take action and run out of excuses. There's a minimum height for safety reasons (eg not to destroy any Raspberry Pis), there's only so often they can claim that is was an operational safety requirement to fly below.
Great idea for a project.
Any recommends on one ADS receiver over others?
nliviu
Wed Sep 09, 2020 10:54 am
Currently I use RTL-SDR Blog V3 R820T2 RTL2832U 1PPM TCXO SMA Software Defined Radio
Other options might be the FlightAware sticks, eg. FlightAware Pro Stick Plus
bls
Contact: Twitter
Wed Sep 09, 2020 2:02 pm
I'm using one of the RTL-SDR USB dongles as well, with FlightAware24. Works well on the Pi. Not surprisingly, it does run a bit on the warmish side. I wasn't ready to make a big antenna investment, so got one on Amazon with a pair of rabbit ears mounted on a tripod indoors, and picks up signals average range 22nm and up to 40nm.
Pi tools:
Quickly and easily build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Easily run your network's DHCP/DNS on a Pi: https://github.com/gitbls/ndm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
pidd
Wed Sep 09, 2020 4:36 pm
Thanks for both replies.
