Draven68
Element14 Case (Picture)
Mon Sep 17, 2012 10:14 am
Just received my case from Element14. $8.73 (AUD)
http://au.element14.com/multicomp/mc-rp ... /211379901
Fits pretty good.
saggel
Re: Element14 Case (Picture)
Fri Sep 21, 2012 3:34 am
I have the same and I love it
halfluck
Mon Sep 24, 2012 2:30 am
Hey Guys,
My Pi Arrived from Element 14 without a case so I used the box it came in.
Very secure and suits my needs
Cheers Rob.
poglad
Mon Sep 24, 2012 8:30 am
Draven68 wrote:Just received my case from Element14. $8.73 (AUD)
Fits pretty good.
Looks great! Is it firm/screwed together, or slightly loose like the Adafruit one?
fladdy
Wed Sep 26, 2012 10:08 am
I'm looking to buy such a case (or similar one) from Germany as I'm in particular interested in a case which allows to be vertically mounted to a wall.
Any ideas where I cound get one or better two of them?
Draven68
Thu Sep 27, 2012 3:03 am
The Element 14 case is a very snug fit... no board movement at all (I did the shake test and drop test on carpet.. and the board does not come loose)
Also, the case can be vertically mounted via 2 mounting slots underneath the case.
Dweeber
Thu Sep 27, 2012 3:17 am
Hard to tell... is there a way to get a cable out from the GPIO pins?
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
Draven68
Thu Sep 27, 2012 7:36 am
Dweeber wrote:Hard to tell... is there a way to get a cable out from the GPIO pins?
There's no slot or holes for the GPIO pins.
Which i'm fine with, as i use the Rpi as a Media Player...
If you plan on using the GPIO pins then i would recommend looking for a different case.
