bazza_11
new project i'm doing and need some help with power
Thu Jan 26, 2017 9:35 pm
So, i'm doing new project with my uni, its getting high power (120V) in with 1kW power limit
my question is, as i'm using raspberrypi 3b it there something you recommend to control the power to raspberrypi and to other subsystem?
i'll have multiple sensors (that could be powered by the raspberrypi itself) but i have a heating element that require about 600-800 Watts
thanks
pcmanbob
Re: new project i'm doing and need some help with power
Thu Jan 26, 2017 10:52 pm
Hi.
Assume by this "raspberrypi 3b it there something you recommend to control the power to raspberrypi and to other subsystem" you mean, "How do you power the Pi".
You will need one of these, :- http://uk.rs-online.com/web/p/plug-in-p ... y/9098126/ ( as no location specified have just linked UK supplier as example )
As for this line "but i have a heating element that require about 600-800 Watts" are you saying you want to control this from the Pi ?
Burngate
Fri Jan 27, 2017 10:46 am
bazza_11
Thu Feb 02, 2017 12:35 am
pcmanbob wrote:Hi.
will, yeah technically. sorry i'm bad at explaining stuff without drawing them out. (attached picture)
Ok so i have a power source coming it, it will power the Pi and the two hotplates.
Then the Pi will be connected to 3 sensors. Also i want it to be connected to the hotplate so i can say turn it on and off
can the pi do that?
Screen Shot 2017-02-01 at 5.31.01 PM.png (56.73 KiB) Viewed 1463 times
bazza_11
Thu Feb 02, 2017 12:36 am
Burngate wrote:You may find this useful:
http://www.pwrusb.com/powerUSB-basic.html
sweet, ya this one aspect that i need, thanks
texy
Thu Feb 02, 2017 1:43 pm
bazza_11 wrote:
pcmanbob wrote:Hi.
can the pi do that?
Short answer is yes, the Pi should be able to do all that. Longer answer is more questions - What are these sensors you mention?
Texy
bazza_11
Fri Feb 10, 2017 8:19 pm
texy wrote:
bazza_11 wrote:
pcmanbob wrote:Hi.
can the pi do that?
Texy
ya, i was wondering, how many sensors that can be connected to the PI?
these sensors require about 3-3.6V and about 900-1500 uAmp (i'll have about 3-4 of those)
Burngate
Sat Feb 11, 2017 11:30 am
bazza_11 wrote:ya, i was wondering, how many sensors that can be connected to the PI?
Much will depend on the sensors (are they simple on-off, or more complicated - i2c for example?)
The 3v3 supply on the Pi could easily supply the 6mA required by four sensors each wanting 1.5mA, through the header.
bazza_11
Mon Feb 13, 2017 7:07 pm
ya, they are bit more complicated, they are thermocouples (Maxim MAX31855 (https://www.maximintegrated.com/en/prod ... 31855.html) ).
Cool, i was bit concerned about if i got 4-5 sensors. and if i can connect all of them to the PI and power them all at the same time.
Mon Feb 13, 2017 7:11 pm
bazza_11
Mon Feb 13, 2017 10:59 pm
DougieLawson wrote:Like this: viewtopic.php?p=1111944#p1111944
Thats amazing! almost the same thing, Thank you very much
