kijix
Portable Camera Project?
Sat Jan 14, 2017 4:35 am
I need something that will snap a photo on a timer every 24 hours and email or upload it to an ftp server. It has to be portable and be able to last at least a month on the same battery charge. It also needs 3g/4g because most locations likely won't have WIFI
I feel like something like this must already exist outside of some type of raspberry pi hack? anyone have any ideas?
Re: Portable Camera Project?
Sat Jan 14, 2017 12:46 pm
You can save power by not running your RPi when it isn't needed. The WittyPi allows you to boot and shutdown on a timed schedule. So you could boot, take photo, shutdown, boot back up 24 hours later.
I have no idea how you're going to find a battery that will power the RPi / WittyPi and last for that duration without having something externally charging it.
http://www.uugear.com/witty-pi-realtime ... pberry-pi/
kijix
Sat Jan 14, 2017 12:53 pm
thanks for the info about witty pi i had not heard of it
since i only want to power on once or twice every 24 hours for only a few minutes at a time, if i got a big enough battery, couldnt that last for 30 days since the total usage time would be lets say 5 minutes per day * 30 days = 150 minutes a month?
Sat Jan 14, 2017 2:17 pm
kijix wrote:thanks for the info about witty pi i had not heard of it
You'll have to run that experiment because only you know what your power budget is going to be.
EULERPI
Sat Jan 14, 2017 3:52 pm
Hopefully expanding on Dougie Lawson's reply I think it depends if the leakage characteristics of the battery will leave you with enough useable energy (required voltage range and required current for specified time) to cover the full time period of your specific application.
Regards
Nick
mosespi
Sun Jan 15, 2017 7:14 am
When developing my UPS I had your exact usage scenario in mind.. among a dozen other things as well.
Run the numbers and see what you can expect.
5 minutes per day at 10 watts (this is on the high side for a Pi).. gives you 0.83 watts used per day
Idle power.. the UPS itself takes about 1ma when powered off.. 0.17 watt used per day
Your total power usage is around 1 watt per day.
NIMH AA batteries assuming 2.5AH, 6 of them of them will give you 18 watts total. Gives you 18 days on six AA batteries.
C cells usually double the power (5AH) and D cells usually double again (10Ah) so the math is pretty easy there. 36 days on C cells or 72 days on D cells.
You can use a common 12v 7 amp hour lead acid battery too.. that has 84 watts or 84 days of power.
There is self discharge and other things to consider if you want to be picky.. I would just subtract 5 or 10%.
Here is my UPS, check the PDF manual, specifically the "UPS Timer Control Settings".
http://www.allspectrum.com/mopower/
You can also use a small solar panel (1-2 watts) to keep rechargeable batteries topped up. Since your power usage is so low it will likely run a long long time even in sub optimal charge conditions.
Regards,
-Moses
Power problems? MoPower UPS for the Pi
Burngate
Mon Jan 16, 2017 6:13 pm
Sorry to butt in, but ... watts and watt-hours ... your calculations don't make sense.
Watts are a measure of power, and is what the Pi uses when on.
Watt-hours are a measure of energy used, and is what a battery can supply before it's exhausted.
So I've corrected it for you ...
5 minutes per day at 10 watts (this is on the high side for a Pi).. gives you 0.83 watt-hours used per day
Idle power.. the UPS itself takes about 1ma when powered off.. 0.17 watt-hours used per day
Your total power usage is around 1 watt-hour per day.
NIMH AA batteries assuming 2.5AH, 6 of them of them will give you 18 watt-hours total. Gives you 18 days on six AA batteries.
You can use a common 12v 7 amp hour lead acid battery too.. that has 84 watt-hours or 84 days of power.
Regards,
-Moses
mosespi
Mon Jan 16, 2017 7:43 pm
Yes, I should have gone with the proper units. Thanks for the correction.
Regards,
-Moses
